camber kit help
Old Aug 23, 2005 | 06:26 AM
VSLOATHE's Avatar
VSLOATHE
Originally Posted by Solracer
Which is Tells me the tire was wearing from incorrect toe. Unless you have extreme camber (like -5+) you are not going to wear just the inside edge of the tire, that is from the tire being dragged across the pavement from incorrect toe settings.
Just got it aligned today. Before the camber kits, it was about -4.5 all around, a little more in the back and a little less in the front.
It was slammed on the previous springs, because the guy buggered up the coilovers and I couldn't raise it. It was so low that I couldn't even fit one finger between the tire and the wheelwell/fender.
Old Aug 23, 2005 | 06:58 AM
Znypar's Avatar
Znypar
ok, in the front, should a ball bearing kit or a control arm kit? and in the rear, do i need a toe adjusting kit in addition to the camber kit?
Old Aug 23, 2005 | 07:04 AM
VSLOATHE's Avatar
VSLOATHE
You probably shouldn't need an extra toe-link unless you're dropping the car really really far in the back. I would get both upper control arm kits for the front and back, you can probably do both for just over 200 bucks and it's worth it to know that you'll have proper alignment all around.
Old Aug 24, 2005 | 06:39 PM
Znypar's Avatar
Znypar
ok, so the control arm kit style is the way to go?
Old Aug 25, 2005 | 05:33 AM
VSLOATHE's Avatar
VSLOATHE
it's what I have and so far I've been REALLY happy with it. They did a full alignment and even re-torqued my steering wheel so everything is perfectly straight. I was doing a buck 20 today (was late to work >_<) and there wasn't even any vibration.
Old Aug 28, 2005 | 09:19 AM
Znypar's Avatar
Znypar
awesome, sounds great, now does anyone have any brand recommendations?
Old Aug 29, 2005 | 06:21 AM
VSLOATHE's Avatar
VSLOATHE
I got my ominpower front camber kit from IAPdirect.com, I bought my Ingalls rear kit from a local speed shop who ordered it for me.
