Throttle body problem
Old Aug 10, 2005 | 11:11 AM
quzur's Avatar
quzur
Default Throttle body problem
First, my check engine light came on. Then I failed emssions because of it. I took it to the mechanic and he said the OBD code PO122 came up...something wrong with the throttle body. He also said that the throttle body cannot be worked on and needs to be completely relplaced. I was quoted something like $1400 for the fix. He said the part alone was $1100. I called Honda and they said the part was $896 and I saw one online for $300. (Edelbrock Part #3811 )
Does this sound right? Has anyone else had any trouble with their Civic idling?
1999 Civic EX
Old Aug 10, 2005 | 11:18 AM
95 SOL's Avatar
95 SOL
Banned
Junk yard can get one MUCH cheaper. It's not extremly common for the sensors to go bad but it can happen. 1400 bucks to replace a TB is REDICULOUS, it's about a 15 minute job and the part can be aquired for less then 100 bucks from the junkyard.
Old Aug 10, 2005 | 11:35 AM
abdelsol's Avatar
abdelsol
Where do you live? For $1400 I will fly in fix it pocket $500, you car will work, I'll throw in a tune up and eveyone can be happy!
Tell them to suck rock....
Quzur has a better idea....
Old Aug 10, 2005 | 11:38 AM
delsol161's Avatar
delsol161
my tb was $289.99 from jegs. works wonderful, and i love it.
Old Aug 10, 2005 | 11:47 AM
shivers's Avatar
shivers
Moderator Alumni
What is the specific code description? Some people have had CELs from dirty TBs. It may just need to be cleaned, but the actual code description would help narrow down the problem.
2005 s2000
Old Aug 10, 2005 | 11:54 AM
delsol161's Avatar
delsol161
good point
Old Aug 10, 2005 | 12:31 PM
quzur's Avatar
quzur
code is PO122
Specfic problem is the Throttle position sensor. They said it cannot replaced on this spcific TB.
I asked if it can be cleaned or rebuilt and the guy said no...I find that hard to beleive. So, its not too hard to install a TB? I might just do it myself if it's not too big of a deal.
Thanks for all the info
Old Aug 10, 2005 | 12:41 PM
delsol161's Avatar
delsol161
some TPSs have two screws holding them on. some are riveted on. depends. find a tps froma junk yard, and it's really easy to install the TB. mine took about 30 minutes. make sure you reseal all the gaskets. better yet, buy new ones.
Old Aug 10, 2005 | 12:44 PM
PahLok's Avatar
PahLok
Lisbon Mafia Connection
Originally Posted by quzur
code is PO122
Even my mother can replace a TB , just don't forget to replace the gasket. Look for a shop manual on the net.. plenty of those around
Here's an example for a 91 B16A1 CRX http://www.honda.co.uk/owner/CRXManual/62sh222/6-76.pdf
Old Aug 10, 2005 | 01:37 PM
quzur's Avatar
quzur
know where I can get that for a D16A?
