ive spoken with people and diagnosed my exhaust smell:
Old Sep 3, 2002 | 07:00 AM
OneToughCivic's Avatar
OneToughCivic
Originally posted by H-A Stud
That's not actually resetting your ECU. Wait till CivicRacer SI gets to the thread. He'll give you the step by step. It's something like...starting your engine....turning it off.....turning the key all the way then starting it...:dunno:
from what i recall, you disconnect the negative battery cable for 10 - 15 minutes and that will reset the ecu...
Old Sep 3, 2002 | 07:08 AM
dantastic's Avatar
dantastic
cx power!
my cx is having a similar problem... ive changed my plugs, wires, rotor, cap, fuel filter, o2 sensor, and my exhaust still smells like crap half the time, and i get cel #1 (bad o2 reading) all the time (its weird b/c it resets every time i shut off the ignition). now im thinking my ECu is bad... i cant figure out whats wrong
Old Sep 3, 2002 | 07:17 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
BTW ~ Yours as bad as mine with the new exhaust? :chuckles:
actually ive got no exhaust right now, but its been this filthy and foul running since i bought it in november.
Old Sep 3, 2002 | 07:30 AM
Fujiwara Takumi
It's my first day.
i got a weird one hte other day, it was some sort of cylinder misfire calculater -- basically meaning the sensor was malfunctioning.
now, to add to the discussion I should make the note that I am getting around 24mpg right now, which is far below average, and thats the SAME whether im driving hard or driving easy.
the smell is sometimes there at idle, but usually its after a hard drive. there is a serious carbon deposti on the inside of my stock tailpipe as well
Old Sep 3, 2002 | 07:36 AM
Nelson's Avatar
Nelson
Administrator
Yup.. either that or just unplug the ECU fuse. Theoretically, if your ECU has no power, the software will reset.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Sep 3, 2002 | 08:56 AM
skubb's Avatar
skubb
not that TLC sh!t either
when resetting the ecu make sure your car is cooled. disconnect negative pole of battery. wait 5-10 minutes. reconnect. start car with absolutely everything turned off and let idle until temp gauge shows normally.
fuji I think that little beast is more trouble than shes worth. rip out that dx piece and make it into a coffee table. heh sorry for no input but I'm no mechanic. did you ever mess with your timing?
Old Sep 3, 2002 | 09:37 AM
Fujiwara Takumi
It's my first day.
like ive said a few times already skubb, she came from the lot with these weird smells. And as far as the coffee table, well, id like to make the mistakes with the throwaway before i pour my heart into a new engine. Right now im thinking about finding a corolla, a midget, or a mini for a daily driver..im sick of the civic bull****. but i digress. I wonder if its as simple as mis gapped sparkies? Timing looks really good, i was playing with the belt the other day, so its nice and tight and wouldnt have slipped.
Old Sep 3, 2002 | 02:26 PM
ManTiS's Avatar
ManTiS
NinJA
Check the plugs then. It's a 5min job.
Old Sep 3, 2002 | 02:55 PM
DakarM's Avatar
DakarM
i second the O2 sensor
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Sep 3, 2002 | 03:06 PM
oc_civic's Avatar
oc_civic
mcc racing
it could DEFINATELY be a plug gap... o2 sensor would probably throw a code... right??? incorrect gap eqauls less ingited fuel euquals more left over fuel equals more rich mixture enough to cause soot and smell..
BullFrogger
Mar 19, 2004 07:50 AM
