The all mighty harness..
Ok, well since install day is one day away. I figured I'd get this out of the way. My b16a harness is all cut up, so I'm going to use my current harness. It's all just plug and play right, all to the same spots? Now, the only problem, adding the wires. I dont get it -_-. I've asked and stuff, but my simple mind can't quite comprehend. People have stated what to do, but without pictures, I'm a dunce. Anyone know a site or DIY for wire adding?
Please use the sticky: https://www.honda-acura.net/forums/s...d.php?t=125370
There's like 100 links there
Har har. I did. A few times, even asked, to no avail. What I'm asking for is help. Not a "use the sticky" comment. All I can really find is stuff like:
If you are running a p28/p30, this applies to you. It may work on other OBD1 ECU/engine setups as well, but i'm not promising anything. Directly from the solenoid you will need to run the green/white wire to pin A4 on the ECU, which is the VTEC Spool Solenoid Valve Control. Next, connect the orange/blue wire to pin D6, which is the VTEC oil pressure switch input. Finally, the black wire from the VTEC pressure switch must be grounded. If you are running a USDM p30, make sure you wire up your knock sensor to pin location D3, otherwise VTEC will not engage.
Sure sounds good. But I'm an idiot. Pictures>text.
Is that all the wires? Are they all on the selinoid?
