i jus got headers and hooked it up but the wires got burnt now my check engine lights is on and my speedometer doesnt work and sometimes goes all crazy wen im driving... i got an obd2 scanner and came up wit 4 problem... my two sensors on the headers, lean operaton at full throttle, and speedo malfunction.. so now i dont know how to fix it.. should i put on my stock headers to see if anything happens because i have a leak n the bottom where the down pipes meet the exhaust pipes...
just rewire it. Clear the codes, and if the lean thing comes back or the speedo thing you'll have to check those out seprately.
( I doubt your TPS or your VSS is bad. )
