DIY A/C Removal?
Originally Posted by Omniscient
Is it just unmouting the compressor, the fan, and the two hoses at the fire wall?
"The a/c system is under high pressure. Do not loosen any hose fittings or remove any components until after the system has been discharged." It doesn't tell how to do that
just to get a grease monkey to DIHimself. So figure that out and then...ENGINE BAY
-Compressor-Receiver/dryer-Condenser-
also the hoses and refrigerant/condenser lines
IN CAR/BEHIND DASH
unless your livin' on the edge, it suggests killing the passenger SRS airbag while your up
under there by unhooking the battery, take out glovebox, and it will be in the upper-left
area of where the box used to be.it's wire wrapped in lume that only has a two-pin connector
anyways, I've personally messed around with it b4, it's pretty obvious how to unmount.
metal clips that look to hold the 2 halfs together on top and on bottom of the evaporator housing. just take a minute to look at it, all you'll need is a 10mm socket(deep sockets help the akward angle) a phillips head sdriver, and a flashlight to make life easier.
*takes a few panting breaths* anything else? out of curiousity, why are you wanting
to drop out the A/C anyways?
If you must remove the A/C just take it to a shop and have them recover the gas first, if all they're doing is recovering it will only take them 30mins @ the most. R134a and R12 (old gas discontinued) refrigerants ARE CFC's. If you must destroy the ozone layer do it with a straight pipe on the track.
Originally Posted by Mario
They key word here is LEGALLY, not easily.
U also need the air box out of a Non ac car. If u put the box that had the evap in it the air flow will sux. And like everyone else is saying go to a shop to have it discharged. If ur caught it some pretty large legal fine to deal with.
