Crank angle sensor ?
Old Aug 21, 2002 | 02:24 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default Crank angle sensor ?
Are the Distributer in a 93 CX and DX the same? B/c i got a check engine light for the CAS and im wondering if it is the Distrbuter, being the wrong one. Please help
Old Aug 21, 2002 | 02:53 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
i had that once, reset your ECU and it will go away. its just a mathematical error you should never see. if its the same error i had.
maybe? i just re read that you had changed your distro.
Old Aug 21, 2002 | 03:41 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I'm probably wrong, but that's not the sensor just behind your crank pulley is it?? Maybe that's crank vibration... I dunno??
Old Aug 21, 2002 | 03:49 PM
Fujiwara Takumi
It's my first day.
im pretty sure it calculates mis fires, and if the misfire is off more than 30% it throws a code to your misfire sensor. Im almost positive you should never see htis light, and most people replace their distributer when they see it.
personally, i reset my ecu and i was fine, but if oyu frankensteined your car, that might be the culprit.
Old Aug 22, 2002 | 04:42 AM
HatchVX's Avatar
HatchVX
All i did was take off my CX head and put on a DX head, and switched out the cx ecu for a DX. I tried to reset it but it didn't go away. It still throws the Craqnk angle sensor out. I know that it is located in the Distributer.
carcrazeeeee
92+ Civic/EL & Del Sol
3
Dec 19, 2008 11:07 PM
AliJ
CRX & Pre 92 Civic
2
Aug 10, 2004 07:33 AM
Tr0LL
Engine Swaps, Tech & Tuning
5
Mar 24, 2003 05:26 PM
Tr0LL
4
Mar 24, 2003 05:24 PM
Raynel
2
Nov 11, 2002 05:57 PM
