It just will not turn
ok, i found the thermostat switch and switched it out, now what can i look to change if the a/c fan does not go on?? i checked the fan relays and fuses and are all fine what makes the a/c fan turn on?
first of all are you expecting the A/C fan to come on when you turn on your A/C? It doesnt work like that. How are you sure they arent coming on? did you idle your car with A/C on high for about 20/30 minutes and stand there to watch the fan? I ask because I was in a similar boat after swapping in my motor. I didnt think my radiator fan was coming on. Turned out I just didnt wait long enough and that I was just paranoid.
Simply put if your car isnt overheating or running really hot (more than half way on your temp gauge) then your radiator fan is probably working. Also if your ac is actually cold... again your A/C fan is probably working.
The A/C condenser fan should be on if the car is sitting still and the A/C is turned on. Otherwise, it won't be cold, like you said. The coolant will get too high of pressure and shut the compressor off. Check the condenser fan fuse under the hood.
Originally Posted by h22afreak
Is your car over heating?
h:
