It just will not turn
Originally Posted by Zzhatch
no it is not, the radiator fan is working fine. My problem is that my a/c is not working because my fan will not turn on. The fan is fine, the fuses and relays are fine, I just need to know what else to check.
sounds like a switch problem to me or a wiring problem. Have you done anything to the climate control recently? Does the AC light come on, and off when pressed? Actually nm, here is the Helms troubleshooting steps for the AC Condenser Fan.
The CLICK you're hearing is the compressor cutting on and off. The car is shuddering because it's under load while the compressor is on. Your AC is working if the compressor is coming on. When the fan is running and you turn the AC on, what happens? Does the fan turn off?
