short ram intake help :confused:
Old Oct 27, 2004 | 05:34 PM
towncarblue's Avatar
towncarblue
Default short ram intake help :confused:
i recently bought this intake
and im having a few problems...
there is an electric plug on the intake that does not fit on the short ram kit . what am i supposed to do with that plug?
what am i supposed to do with the brackets??
File Type: jpg
Old Oct 27, 2004 | 06:26 PM
MilanoMan's Avatar
MilanoMan
98 Civic Ex
I ran into the exact problem. If the MAF (electronic mass airflow sensor does not fit into one of the holes, the hole is probably welded poorly, not allowing it to fit in it all the way. Take the intake to a shop and have them sand inside the hole, and you might have to cut the hosing to allow the sensor to stretch to reach the hole...as far as the bracket, put it where the stock airbox bolts where and use zipties around the intake and throught the holes, do this to two of the holes on the bracket, and the intake will be a little loose up and down, not too much, but you don't want it stiff. Hope this helps, ask if I'm being vague and you need more info.
EDIT: Haha, that's my exact intake, the 90* bracket you won't need...also, the MAF sensor didnt plug in, so I think there is poor welding on these specific intakes, have a shop sand the inside of the hole, and blow the metal particles out.
Old Oct 27, 2004 | 06:51 PM
towncarblue
i think that tube that comes with the kit is used for that electrical plug. i could be wrong and i cant verify right now
Old Oct 27, 2004 | 07:13 PM
MilanoMan's Avatar
MilanoMan
98 Civic Ex
not at all man. That goes on the hole from the valve cover to the hole on the intake...I can show you a pic, lemme go take one and upload it.
Old Oct 27, 2004 | 07:26 PM
shifty35's Avatar
shifty35
It's not a MAF, Honda's use MAP (Manifold Absolute Pressure) sensors instead. The sensor in the tube is an IAT, Intake Air Temperature.
Old Oct 27, 2004 | 08:12 PM
MilanoMan's Avatar
MilanoMan
98 Civic Ex
Yeah, you're right...used to my MazdaSpeed protege
Old Oct 27, 2004 | 08:16 PM
towncarblue
so can i just leave that electrical piece hanging??
Old Oct 27, 2004 | 08:18 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Stock intake w/ K&N > short ram
Old Oct 27, 2004 | 08:21 PM
MilanoMan's Avatar
MilanoMan
98 Civic Ex
No man, re read my post...If you leave it hanging it can cause your car to run rich, and f--k up your engine.
I can try to write in more detail tommorow, but I have a meeting at 6:00 so I need to be getting some sleep.
Old Oct 27, 2004 | 09:00 PM
Kai's Avatar
Kai
Rotorphile.
I ran into the exact problem. If the MAF (...)
:lmfao:
You're kidding me... the MSP still uses a MAF? The RX-7 switched from AFM's to MAP's in '93, I'm suprized the MSP would still use a MAF.
(Note to to Honda guys that don't understand: AFM = Air Flow Meter, MAF = Mass Air Flow sensor. Yes, there is a difference. )
