short ram intake help :confused:
Yeah, unless my mech friend that works at mazda is wrong (which he very well could be), it uses a MAF. Maybe he just means the only electrical component that goes to the intake
You will be left with a hole on the intake that you don't use assuming you're installing this on a 96-00 Civic...probably an EX/Si...just put a hose to it and clamp it off so you won't get any vacuum leaks, or if it comes witha plug, plug it off. Don't run with an open hole.
hehehe, yeah, guys don't buy those cheap air intakes, those are the intakes you always see in ebay for $5... I found these pics, if you need help, just PM me I'll help you with the installation... it's really easy
Originally Posted by teg92
should of kept your stock one it proballys looks better than that one IMO
I don't blame you
h:
