do i need a new axle?
Old Oct 25, 2004 | 08:23 PM
loctoday's Avatar
loctoday
Default do i need a new axle?
i have a 98 civic ex...i was replacing a stud..took off the 32mm axle nut...but i guess when i took it off i stripped the shaft part...i bought a new nut...but that wasn't the problem...do i need to change the whole axle?...if so is there a diy site? thanks
Old Oct 26, 2004 | 04:45 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
Its pretty easy, basically drain your tranny, then on whichever side the axle is on, disconnect the controll arm from both the subframe and the fork on the shock. then you can just swing the whole assembly out of the way, pry the axle loose from the tranny and hammer it free from the spindle. If done right it looks like this.
Easier than seperating the ball joints.
Old Oct 26, 2004 | 05:54 AM
h22afreak's Avatar
h22afreak
IN BOOST WE TRUST.
you might want to change that axle and why do you think its
easier to change the axle that way,in my opinion i think you are over
working yourself.
Old Oct 26, 2004 | 06:05 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
over working myself by removing 4 bolts? Jeez youre right Im working myself to death. heh. That axle was replaced. This photo was taken while I was swapping to a B18C.
Old Oct 26, 2004 | 07:12 AM
honura's Avatar
honura
Seni
Looks like it was harder at first but seems to work better that way. You don't have to bang the shet out of the joints.
Old Oct 26, 2004 | 09:16 AM
loctoday's Avatar
loctoday
aite coo...i found it at autozone for like 60 bux with lifetime warranty...with the 45 core charge...
Old Oct 26, 2004 | 09:23 AM
Civic2Scooby's Avatar
Civic2Scooby
:werd: thats how I do all my axle swaps...it takes me a grand total of 10 minutes to swap out an axle this way, and way longer if I try to pop the ball joints etc.....
Old Oct 26, 2004 | 12:25 PM
loctoday's Avatar
loctoday
ok, im wondering if the new axle will come with wheel bearings?..i want to replace those too..since im taking all of this off
Old Oct 26, 2004 | 12:32 PM
monicle's Avatar
monicle
Repo.Jackmoves.Com
nope they wont come with those are a seperate piece and therefore extra $$
