taking off the stock intake tubing?!?!
Old Aug 7, 2004 | 09:27 PM
Jafro's Avatar
Jafro
I'm made of meat!
You should have seen me scooping the intake out when I was changing the filter... going... WTF? How? Why? Huh? !!!!!!
At my parents house, the squirrels ate the gate right off of the fence (it was wood, now they've replaced it with a steel gate that looks like wood). They lick the salt off the bricks on the walkway outside their front door. Last Christmas, one kept unscrewing the Christmas lights outside the house and burying them in the flower beds. They caught him with a video camera because they couldn't figure out WHY their lights kept disappearing. They thought someone was playing a trick on them. Squirrels can be some crafty little bastards.
... so get an intake and get rid of that stock Habitrail hamster cage. It doesn't have to be expensive. My CAI came from eBay and cost $36 shipped. It's worked out great.
Old Aug 8, 2004 | 06:28 PM
Cbakey's Avatar
Cbakey
gas mileage is fine. went from 35 to 34. drop is most likely from me getting on the throttle too much.
File Type: jpg
File Type: jpg
File Type: jpg
Old Aug 9, 2004 | 02:04 AM
saga's Avatar
saga
broke college kid
there's no way the air going into your engine is cool at all now.
Old Aug 9, 2004 | 02:39 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
yovue ruined the engineering behind the reason the box is at the front of the engine.
Cool air is good for your engine, hot air is bad...
And if you think about it with hot air your more likely for detonation, given thatd be unlikely.
Just put it back on, I dont see the point behind taking it off at all, it can't be for performance, because with less cold air all it would do is impede performance.
Old Aug 9, 2004 | 07:14 AM
Cbakey's Avatar
Cbakey
performance you say, what performance dose a Stock civic have?
Old Aug 10, 2004 | 09:02 AM
old_forester1's Avatar
old_forester1
Default Performance
The motor should run OK without the intake tube that runs to the wheel well, but maybe not as efficiently. The tube allows the engine to take in colder air than that above the engine. Why would you want cold air? It's because cold air is denser and heavier than warm air ..... meaning that there is actually more air per cold cubic foot then in a warm cubic foot... so in theory you are delivering a higher volume of air into the engine. And the more volume of air you can put in the cylinder the more powerful the explosions are going to be..........need I say............ more horsepower. If horsepower isn't a consideration, take the intake tubing off.
Old Aug 12, 2004 | 05:21 AM
flatfourfan's Avatar
flatfourfan
VTEC or FLATFOUR?
Default looks similar to my old dx CARB set up
Double carbs ona d15somethingor other JDM, pissy little small things..about 23 vacuum tubes.... I was getting about 5.5kms to the litre, dunno what the is in gallons and miles, but I'm getting triple it now with fuel injection, aftermarket efi and a SOHC vtec swap..still auto by the way.
File Type: jpg
File Type: jpg
Old Aug 12, 2004 | 05:22 AM
flatfourfan
VTEC or FLATFOUR?
Kind of looks like my old 92 civic dx CARB set-up
Double carbs on a d15somethingor other JDM, pissy little small things..about 23 vacuum tubes.... I was getting about 5.5kms to the litre, dunno what the is in gallons and miles, but I'm getting triple it now with fuel injection, aftermarket efi and a SOHC vtec swap..still auto by the way.
Old Aug 12, 2004 | 03:55 PM
Kai's Avatar
Kai
Rotorphile.
That would've been fun if you swapped a couple webers onto it.
Old Aug 12, 2004 | 11:32 PM
flatfourfan
VTEC or FLATFOUR?
Default yeaaah
I was thinking about it, but there was no place to mount anything, I think that they were either twin 31's or twin 32's, they looked good, but they were utter JUNK. I tried to see if I could fit either a 44IDF or better yet, a set of IDA's.....there's just no space. Would look good, with a subaru type scoop at the back of the bonnet......lol.
