new springs... spring rate
i dont have alot of money but i want a stiffer spring rate, i have a eibach pro kit now. with stiff a$s struts. but i want a better stiffer spring rate. what would you all recommend? sportline... tien-s, nuspeed race? I DONT WANT COILOVERS been there dont likem. i got a baby boy that takes rides with me sometimes too....
thanks for your imput...
i don't know what the spring rates of ANY of those springs even are... I think the difference is more in spring length than rate. Call up the manufacturers and ask for rates, and I'll be able to give you a little more info from there.
If you really want to customize your spring rates, you'll need to go with ground-control (or other coilovers with multiple spring rate availability). There is nothing inherently poor-riding about coilovers... your previous experience was probably due either to poor quality coilovers, inapropriate spring rates, or mismatched shocks.
:edit: Looking at your sig, I think I may have found your problem. I wouldn't expect "dropzone" struts to ride or handle worth a damn.
Originally Posted by TeHJuSTiN
pos drop zone struts.
Tein springs (the S-Tech) are really soft.
Here are some rates, but they are for 96-00 spec Civic's...
Your Pro-Kit: 290F, 190R
Tein S-Tech: 235F, 140R
Neuspeed Race - 485F, 395R
I believe Integra rates are higher, if that is what you would like.
You should note some rates are progressive, some are linear... all depends on spring application.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Not sure if those Blue's can handle a harsh spring rate (the Neuspeed Race).
If you want a lowered stance with some comfort, I would have to say the Tein S-Tech's are a perfect fit for you and they are reasonably cheap.
Good luck.
Good luck.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Good luck.
Good luck.
Originally Posted by 92eg6
i want stiff i dont want my car to lean on turns stuff like that. i have a prokit whats your reccommend
I would look into:
H&R Sport - 330F, 280R
They are a little stiffer and would work on your current shocks.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Oh, I mis-read. I think you'd have problems with your shocks blowing out if you run too high of a rate.
I would look into:
I would look into:
Are H&R Sport good springs?
