window problems
when ever i raise up my window, it seems to push itself off the track at the very top, and at the bottom of the window it does not come up all the way. so its kinds like it is going up at a slant. it doesnt bother me to much because i have those weather guards and they keep the elements out of my car, but its still aggervating because you can here the wind on the windshield. if anyone can help that would be great, other wise im gunna have to head down to my local honda dealer to tear that shiz apart, and i hate those guys
gots the same porblem on my 99 ex dude... its not that hard to put the window back in the railing but like u said its a pain......it seems like the rubber guiding thing on the railing inside the door tends to wear out i guess... i tried wd-40 on the railing and it helps for a while. just lube everything up. it only falls off the rail when i put the window all the way down. so i keep it half way for now just in case it does happen. dont wanna be taking apart the door panel @ the mall or something u konw?
I had the same issue a while back. you can try the adjustment on the lower part of the window and the window regulator arms, but more than likely you will have to pick up the rubber track that fits into the door. solved it for me.
DMA94ls
5
Sep 6, 2003 10:30 AM
