lighting problem
Old May 29, 2004 | 01:59 AM
Ray2943's Avatar
Ray2943
Default lighting problem
Does anyone know why my passenger headlight is dim compared to the other side and my turn signal will not turn on when my lights are on? My turn signal will turn on only if I don't turn on my headlights. Also my signal light in the rear looks like it is on...not blinking. Thanks
Old May 29, 2004 | 02:15 AM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
sounds like an element in bulb burned out.
Old May 29, 2004 | 02:22 AM
Ray2943's Avatar
Ray2943
what would i need to do?
Old May 29, 2004 | 02:48 AM
dE.fUsEd's Avatar
dE.fUsEd
replace the bulb. it's most likely your front blinker bulb. pop it out, take it to autoparts store and get a new one.
Old May 29, 2004 | 05:50 AM
str8edgexx's Avatar
str8edgexx
If one side is dim and the other is normal, it may be a problem with a relay
Old May 29, 2004 | 06:46 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
OR, the headlight may not be grounded correctly. I once removed the bolt that holds a plastic piece with a metal tab where it bolted to the body and a bunch of wires coming out of it. I couldn't figure out why one headlight was really really dim while the other was just fine. Turns out I forgot to put that plastic piece back on and that it had a metal tab because that was a gound. h:
Did you do anything right before you noticed it was doing what it is?
hih
Old May 29, 2004 | 09:12 AM
Ray2943's Avatar
Ray2943
i did not do anything before.
Old Mar 22, 2005 | 10:34 AM
yellakick's Avatar
yellakick
hih
hey do you know where the ground is? im having the same problems...
lx_rob
Accord
Mar 22, 2004 03:00 PM
jaxrunner
May 4, 2003 12:48 PM
AadosX
Accord
11
Mar 14, 2003 09:53 AM
my95si
92+ Civic/EL & Del Sol
12
Feb 12, 2003 12:24 PM
The Dude
Aug 10, 2002 08:09 AM
