lighting problem
Old Feb 10, 2003 | 05:18 PM
my95si's Avatar
my95si
Default lighting problem
can anyone tell me what would cause my driver-side light to just stop working its not a fuse i check those...can anyone shine some light(no pun intended) on this problem.thanks
Old Feb 10, 2003 | 05:51 PM
Tirod's Avatar
Tirod
bulb burn out? faulty wiring to the bulb.. harness??
Old Feb 11, 2003 | 02:04 AM
Kai's Avatar
Kai
Rotorphile.
Originally posted by Tirod-slc
bulb burn out?
:chuckles:
You did check the bulb first, before posting... didn't you?
Old Feb 11, 2003 | 12:23 PM
my95si's Avatar
my95si
i did check the bulb and the harness but they look fine what else should i look for?
Old Feb 11, 2003 | 12:44 PM
dantastic's Avatar
dantastic
cx power!
did u actually try replacing the bulb 1st? it costs $1.99 for 2, or u could just switch it with the one from the passenger side. h ave a 10 yr old civic, and a 7 yr old accord... the wiring has always been ok...
Old Feb 11, 2003 | 01:27 PM
str8edgexx's Avatar
str8edgexx
bad relay maybe?
Old Feb 11, 2003 | 02:30 PM
ManTiS's Avatar
ManTiS
NinJA
My money is on the bulb is burnt.
Old Feb 11, 2003 | 09:31 PM
Kai's Avatar
Kai
Rotorphile.
Exactly. When I said "check" the light, I ment replace. Light bulbs can look fine even when they are burnt out.
Old Feb 11, 2003 | 09:38 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
sometimes true...but usually the filament is burnt and u can hear it rattle if you shake the bulb, it's pretty obvious.
Old Feb 12, 2003 | 06:40 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I've had this problem before and it was a bad ground. There's a little white/clear connector just behind the headlight that is rectangular with a metal tab that comes out of this. This metal tab has a hole in it where it is supposed to be bolted to the body. You didn't remove this by chance did you? If so, you have removed a ground from the headlight wiring.
Just a thought.
