wiring?
Old May 9, 2004 | 04:31 PM
importkustoms00's Avatar
importkustoms00
Korean DOOD
Default wiring?
ok i know i should have put this in the audio forum but this is a question for civics. ok when wiring up a amp where is the hole in the firewall that u use for the power wire for the amp. and another question where is the best place to run the wire as in tryin to hide it? i dont wont no ghetto lookin install. any please
Old May 9, 2004 | 04:46 PM
92eg6's Avatar
92eg6
99 CG3 Owner
there are many, one under the vertical wall on the passenger side, and same on the drivers..... its easyer to do the passenger side, just take your carpet pell it back where your feet go, and reach your hand up high, you'll feel the plug. remove it.... do the same on the engine side, cut a hole in both plugs and put them back on to keep the wayter out. then put it all back together
Old May 9, 2004 | 04:52 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Bust out a wire hanger and use that to pull the wire thougha boot in the fire wall.
Rust the wire down the same side as the battery UNDER the carpet/interior panels. Any place it's exposed cover it with split loom.
Old May 9, 2004 | 04:55 PM
importkustoms00
Korean DOOD
thanx man anything else i should be aware of
Old May 9, 2004 | 06:08 PM
importkustoms00
Korean DOOD
WTF i cant find that ****in shit!!!!!!! where tha **** is it? what color is it? do i have to pull that shit thats under the carpet too?
Old May 9, 2004 | 06:09 PM
importkustoms00
Korean DOOD
maybe im dumb but whats tha vertical wall?
Old May 9, 2004 | 06:51 PM
mulletov's Avatar
mulletov
Open up the hood and look at the battery. To the right of the battery and down low on the firewall, you'll see the black rubber grommet. Thats where you wanna poke the wire hanger through. Remember to poke in a downward direction or your hanger won't go anywhere.
Old May 9, 2004 | 07:44 PM
importkustoms00
Korean DOOD
thanx hold on il go try that
Old May 9, 2004 | 08:25 PM
importkustoms00
Korean DOOD
OMG dude thanx so much ! u just saved me like 50 bux ! i appreciate it alot .
acuragal03
7
Mar 31, 2004 07:10 AM
LateApex
Engine Swaps, Tech & Tuning
13
Oct 29, 2003 09:10 AM
LateApex
2
Oct 24, 2003 02:07 PM
saber1
Apr 6, 2003 06:56 AM
