to turbo or not to turbo
Old May 5, 2004 | 04:00 PM
93DelSolSi's Avatar
93DelSolSi
Originally Posted by Jafro
Buy this car for $300
...and bolt a non-turbo 4g63 in it for about $400 and run low 14's, or go for a JDM turbo 4g63/tranny/ecu combo for about $1200 and go run 10's. Have a car that cost $1500 less than you were going to spend, and also, could have the fastest hatch on HAN.
Reliability...
Turbo: How good of a mechanic are you? If you swap it yourself, you shouldn't have any problems.
Non-Turbo: Rock solid for 200k miles if you just change the timing belt and oil on time.
Is that for sale ?
Old May 5, 2004 | 05:00 PM
Jafro's Avatar
Jafro
I'm made of meat!
Originally Posted by 93DelSolSi
Is that for sale ?
I think so. The owner transferred his tags to another car. The rear main seal was replaced, and a week later the car shredded its flex plate (it's an automatic). So the owner is trying to get the money back out of it from the rear main seal replacement. $300 is the highest offer so far. It runs, but doesn't drive. The rings are gone. The interior sux (so what). This is the perfect 4g63 swap candidate (because the turbo cars didn't come in this color). I've always wanted to get one of these and convert it to AWD/Turbo like the JDM Syborg. I only know of 2 people that have done that in the whole US, but you'd need a whole AWD '91 T/E/L donor car to do it.
2gr84u: If you're going Honda, and you're sitting a D16, do something original, do it right. Replace the rods and pistons with aftermarket forged stuff, and then turbo it. You'll get much more fun and reliability out of it than if you didn't. Too many D16 owners have to settle for 6 PSI, and I'm sure the motor has more RELIABLE potential if the bottom end is built for it.
Old May 5, 2004 | 05:42 PM
93DelSolSi's Avatar
93DelSolSi
(it's an automatic)
you lost me there
Old May 5, 2004 | 06:01 PM
Jafro's Avatar
Jafro
I'm made of meat!
Not a big deal, really. No way I'd leave an automatic in there after removing the old worn-out 4g15. The tranny would have to be replaced anyway if it gets a turbo swap... You can buy that whole engine/tranny setup complete sometimes for less than $800.
Old May 5, 2004 | 06:07 PM
93DelSolSi's Avatar
93DelSolSi
thats cool
Old May 5, 2004 | 09:48 PM
Kai's Avatar
Kai
Rotorphile.
So... uhh... what kind of car is that, anyway?
David:
Step 1: Fix car.
Step 2: Worry about modifying it after you can actually drive it.
Old May 6, 2004 | 05:17 AM
illicon2003's Avatar
illicon2003
do some research..jesus christ. www.turbod16.com in the faq and other places will explain all of your questions and then some.
Old May 6, 2004 | 07:23 AM
Jafro's Avatar
Jafro
I'm made of meat!
That's a '91 Mitsubishi Mirage. It's the exact same thing as a Dodge Colt, a Plymouth Champ, or a Hyundai Excel. They all use a 4g15 engine except for a RARE select few who have a 165hp turbocharged 4g61 engine (1.6L DOHC), those ran mid-15's from the factory because they weigh 2000lbs.. A 6-bolt turbo DSM drivetrain bolts right into it because all the 4g series engines from the same year have the same motor mounts. That includes the 210hp/209tq 4g63's. You can build a Viper killer for under $2500.
Man, I'm so tempted.
