leak in passenger when ac on
Old May 2, 2004 | 09:52 PM
NOSon's Avatar
NOSon
Default leak in passenger when ac on
it looks like water is leaking down from the dash to the carpet in the passenger side of the car when the ac in on. what causes this?? and how do i troubleshoot it??
Old May 3, 2004 | 02:04 AM
ragerized's Avatar
ragerized
dc4 ownerages
your ac is leaking into your car. find where its leaking and stop it. look up under the passenger side of the dash.
Old May 3, 2004 | 03:54 AM
CivicRacr's Avatar
CivicRacr
kinda sounds like condensation and theres just enough of it to collect water and drip down on the carpet.
Old May 3, 2004 | 03:19 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
its dripping from the evaporator... It may just be condensation, or it may be an actual leak. How much drips?
Old May 3, 2004 | 03:51 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
this is an old skool problem with all hondas. Under the dash, where the blower motor is, there is a drain tube that lets all the rain water and shit out. It normally gets pinched, or bent from your floor mat hitting it, or just from being put in goofy. If you can straighten it out, it may girgle and clear out. If you pull it off, you may get a ton of water dripping in. So, if it doesn't girgle, pull it off, and blow it out with an air gun. Should work fine after that, and you'll be dry for another 8 years.
It happens a lot with the 4th gens (takes about 6-10 years for all the shit to build up, depending on where you park, like under a tree...)
I've had it happen on every honda I've owned.
Old May 7, 2004 | 11:53 PM
NOSon's Avatar
NOSon
it drips alot. Drips everytime i turn on the ac. the dripping is from behind a tube sort of like. there's a small hole behind and thats where it's dripping from. Is there suppose to be a plug for that hole?
Old May 8, 2004 | 12:02 AM
Kai's Avatar
Kai
Rotorphile.
basically, as the air is dehumidified (from being cooled) water will pool in the evaporator box. There is a drain hose to clear out this water, but if the hose is clogged or disconnected it will drain back into the car. Take off this hose and either clean, replace, or reconnect it and it will be fine.
Old May 8, 2004 | 12:24 AM
NOSon's Avatar
NOSon
where's the draining hose?
Old May 8, 2004 | 02:57 PM
NOSon's Avatar
NOSon
ok i found the hose and fixed the leak. thanks.
civicfan8
92+ Civic/EL & Del Sol
11
Apr 1, 2004 09:43 AM
DavE96GsR
12
Mar 2, 2004 09:49 AM
izod
10
Feb 18, 2004 06:28 AM
Pelka
Prelude
2
Nov 3, 2003 02:09 PM
kilabeez
Prelude
Nov 22, 2002 03:56 PM
