Removing A/C - what else?
Honorary Moderator Alumni
i found the biggest pita was removing the lines that go in front of the radiator under the support. These were a bitch to get out. It would help to undo the upper radiator mount and lean the top of the radiator back towards the motor. Also, the lines that go under the battery are a bitch unless you remove the battery tray.
all in all (including the conderser, compressor, evap core, dryer, fans, bolts, brackets, lines, doodads, thingamajigs) it weighed in at 38lbs.
Autocross Help Page
Autocross Help Page
you should remove the compressor too. really thats where the bulk of the weight is. The condenser and fan really don't weigh much... maybe 5 pounds... the compressor weighs probably a good 20-25 pounds.
Originally Posted by MaxBoosT
I'd say CTR crank pulley :naughty:
Originally Posted by igo4bmx
if you wanna go hardcore and don't mind noise, get rid of the sound dampening shit in the trunk.
Also helium in your tires always helps :rofl:
Autocross Help Page
Autocross Help Page
2 damn dark
92+ Civic/EL & Del Sol
2
Jul 18, 2003 09:15 AM
stealthteg
26
May 5, 2003 02:19 PM
