b18b or b16a2?
I know this guy and he's looking for an engine to swap into his hatch. Is there any information someone could give on what would be needed for the B16A2 swap.
Would an OBD I or OBD II ECU work? Any info on what needs to wired up.
Thanks in advance fellas.
If it came down to a race between two identical cars, identical drivers, only difference being the motor, it would be damn close. Really the only basis to make this decision is what your preference is. If you like waiting for a strong power kick at the top of the tach, the b16a is for you. If you like putting your foot down and feeling the car pull strong and then have the fun stop earlier, the b18b is for you.
I personally would prefer the b18b out of the two. Torque = versatility.
Originally Posted by Kai
Turbo B18B > turbo B16A.
Why?
Displacement.
Why?
Displacement.
b16a = more compression
more compression = more power per lbs of boost.
b16a = better gearing = better acceleration
b16a = longer power band
wned:
B16A = no torque
B16A = needs to rev to high hell to make power
B16A = short gears = more highway revs
B16A = more compression = less aggressive tuning or knock knock knock!
B16A = shorter deck
239cc's is a big difference in a four cylinder. :fawk:
B16A = shorter deck
B16A = no torque
B16A = shorter deck
B16A = shorter deck
turbo = flatter power band
more highway revs? are you serious. were talking power, not vaginal discomfort
more compression turbo = less room for error, but doesn't necessarily mean knock knock.
yes. it does have a better rod to stroke ratio than the b18b
Originally Posted by Bumnah
no honda's have torque
Forgot to mention that too, a B16A needs high test gas, a B18B does not.
