smoke
Old Apr 25, 2004 | 04:32 PM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by 93SoL
how could i find the vacuum leak and it could either be the fuel pump or filter
spray your vacuum hoses with wd-40 if the rpm increase slightly then you found your leak.....when is the last time you changed your fuel filter?
are you running a motor swap, or just the stock D series? if you are swapped did you change to a B series fuel line.....need more info
Old Apr 25, 2004 | 04:48 PM
bambbrose's Avatar
bambbrose
small vacuum leaks are kinda hard to detect.. the proper method is to use propane while the engine is running and spray it around the seals of the TB, intake mani, hoses, etc and it will make the engine bog down (running to rich from the propane)... but most people don't have the tools to do that. I've never heard of the WD-40 method but it seems very similar to the propane one so I think it would work. It could be both the pump and/or filter but I would change the filter first, especially if you don't know when it was last changed.
A lot of hondas puff white smoke when you shift hard and floor it, I've noticed most of the higher revving ones do that. I'm not sure exactly what the reason why is however. Might be related to the valvetrain. I think we need someone with more expertise to help you out
Old Apr 26, 2004 | 09:16 AM
93SoL's Avatar
93SoL
lazy a55
ok what i have done was a mini me swap well just the head off a z6 and a high flow cat. and i dont know when my fuel filter was changed. well it started doing it when i put the new ecu in
Old Apr 26, 2004 | 01:06 PM
bambbrose's Avatar
bambbrose
oh that is the kinda information that we needed. I bet you are just running lean because the ecu isn't designed exactly for your engine.. maybe you have a slightly different CR or something. What ecu are you running? p28?
Old Apr 26, 2004 | 07:47 PM
93SoL's Avatar
93SoL
lazy a55
yup a p28 i replaced the fuel pump my other was almost gone.... now it just barely smokes...my fuel pressure is 35psi...idles alot better since the fuel pump replacement. on my high flow cat its just a gutted out integra cat. maybe its just smoking cause of that
88Cardrex
CRX & Pre 92 Civic
17
Oct 23, 2005 08:00 AM
wayne99integra
2
Apr 24, 2004 06:19 AM
MrFatbooty
Jan 2, 2004 09:52 PM
mxl36o
92+ Civic/EL & Del Sol
8
Nov 23, 2003 12:38 AM
