smoke
ok when i driving around its normal but if i drop a gear and floor it white smoke comes out just when i floor it. my fuel pump could be giong out but if its nething else can u tell me......
I change my oil over the weekend and my came out pretty dark, however I made a nasty mistake and forgot to change my oil filter when I changed my oil last. I just did my swap and then changed it but forgot the filter....
nice hey
That could be the prob
nice heyThat could be the prob
haha this thread is funny. first what you need to do is tell us what color the smoke is. white is usually headgasket... bluish black is usually burning oil (piston rings), black means you are running rich.. there are a ton of possibilities. whats the color? how many miles does your car have?
My guess, since it's only at WOT, is that you have poor sealing piston rings. I would do a compression test and post the results
edit: I didn't read carefully
h: since it's white smoke then I would bet you are just running lean at WOT, which could be either a fuel issue like a fuel filter or similar, or maybe a small vacuum leak causing a slightly lean condtion
