Civic with LS HARD TO SHIFT?
The bolts I"m guessing they're refering too are the one below the shifter. There are two that go through a rubber bushing that hold the shifter up in the car back under your exhaust system. I guess if they're tighened down too far, you could have a binding issue?
A slave cylinder is the part bolted to the front of the tranny that actually pushes the pressure plate, going through a swing arm (right word?) and then the throwout bearing, when you push the clutch pedal in. You can identify it on the front of the tranny as a little black metal cylinder with 2 bolts holding it to the tranny. It will have a hard brake line going to it, a bleeder on 1 side and the other side will go into a square rubber boot. It may be the issue, as well as the clutch master cylinder which is bolted to the firewall and is right of the brake master cylinder if your looking from the front. I'm guessing you checked the tranny had fluid?
Originally Posted by Jason852001
As I said earlier yall have been a great help. If I could just get a little more help. Can somebody tell me more about the slave cylinder? How much would it cost to get one fixed?
1. i payed 12 bucks for mine at a auto-part store.
2. you can fix this yourself with not really any problem at all.
b18c1delsol94
Vehicle Classifieds
21
May 12, 2004 12:53 AM
Daniel
News & Rumors Archives
Oct 6, 2003 11:37 AM
jbontke
CRX & Pre 92 Civic
10
Aug 14, 2002 07:17 PM
