b16 a bog????????/
b16 a bog????????/
my buddy justput a jdm b16a in his 93 hatch now when he makes a right hand turns it seems that not enough gas is going to th engine
has this happend to anyone b4?
any ideas?
thanks
any ideas?
thanks
I am tehguy... OH YEAH!!
Check the fule lines, but I dont think it would be problem with the fuel lines if it only happens when you make a right turn. Unless theirs some reason that when you turn one of the lines is getting pinched
Which fuel line is he using???
If he's using the fuel line from the hatch he's setting himself up for failure..
You need the fuel line from a b-series engine ..you can pick one up from the delaership brand new for less than 20 bucks from a 94-97 del sol w/b16 or a 99 SI.
Good luck
And what CELs is he getting.
Good luck
Originally Posted by 98teggs
yeah he is getting a srs light
did he switch over to the integra or 99-00 si fuel line? if he is trying to run his stocker fuel line then I think he should start there.
untensadude
11-14-2003 03:51 PM
