Questions on '97 EX swap to B16
Old Nov 9, 2003 | 12:19 AM
Gweedoh's Avatar
Gweedoh
Default Questions on '97 EX swap to B16
Hey all,
I blasted the #4 connecting rod out of the bottom of my oil pan. I am looking for some advice on a B16 swap for a '97 EX.
My options at this point are staying with the D16 or going to a B16 with tranny and ECU. I'm not considering anything over the B16.
My questions are these:
1. Which B16 is best for the 6th gen coupe (b16a, b16b or b16c) and what's the difference?
2. Exactly what parts am I going to have to change (exhaust, wiring, brackets, linkages, mounts, etc)?
3. What's a good price for a B16 with tranny and ECU?
I'm looking for advice from people that have done this swap or links to sites of people that have done it.
Thanks for the info!
-Dave
Old Nov 9, 2003 | 07:47 AM
Gweedoh's Avatar
Gweedoh
Something I forgot to mention. I'm doing the swap myself, so prices need not include installation.
Old Nov 9, 2003 | 08:28 AM
Paul's Avatar
Paul
Eater of Rice
Default Re: Questions on '97 EX swap to B16
Originally posted by Gweedoh
Hey all,
-Dave
1. B16A2 is meant to be in your car, you could just as easily swap in a B16B, as for the B16C, I haven't ever heard of that craziness.
2. You'll need to use a mix of mounts, you'll probably have to get your exhaust lengthened. The B-Series manifold is a bit shorter than the D-Series. You'll want to use the B-Series wiring harness, but you can use the D-Series and run some extra wires. You'll want to use the B-Series brackets, the B-Series linkage.
3. I see B16A2's going anywhere from $2000 to $3000. I wouldn't pay any more than $2500 shipped for a complete swap.
Old Nov 9, 2003 | 02:18 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
obd1 sir2 b16 is more work than you probably want
b16b should go right in
b16a2 (si) I thought you had to change out the whole engine harness/do lots of rewiring because of lots of little shit that wasnt compatable
Old Nov 9, 2003 | 02:55 PM
Civic2Scooby's Avatar
Civic2Scooby
b16b if you can afford it would be the best. b16a from the same generation as your car should be pretty straight forward. add a few wires here and there and get some different mounts and linkage.
