Exhaust For Itr Swap?
Old Apr 12, 2004 | 08:03 AM
mobius's Avatar
mobius
Default Exhaust For Itr Swap?
00 Ek Hatch To Itr Swap...
Going For The Full B18c5 Swap At The End Of Next Month! I Wanna Get Everything Ready Now So It Will Be Easy To Manage When I Put The Engine In. What Would You Recommend I Do For Exhaust In This Setup. I Don't Plan On Doing Turbo, Just A Na Setup For Now. I Was Thinking Apex-i Wsii And A High Flow Cat.
Old Apr 12, 2004 | 08:40 AM
jmk2888's Avatar
jmk2888
How about a RS*R Cat-Back Exhaust, ITR header, and a 2.5 High Flow Cat?
Old Apr 12, 2004 | 08:42 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Sounds like a good exhaust setup. What header are you thinking?
Old Apr 12, 2004 | 09:18 AM
mobius's Avatar
mobius
Was just gonna use the ITR header that came with (CTR prolly would work better). I'm not sure, but i think that stuff doesn't all bolt up exactly right. Might have to make a custom flange into the cat on either the exhaust or header. Am I right?
Old Apr 12, 2004 | 09:26 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
I have a 97 ek with a jdm itr b18c. If you get a jdm header: I went with the T1R (type one racing) exhaust. It is 2.5" and allows room for a cat. If you get a standard dx/cx usdm exhaust it will be right at the header leaving no room for a cat. The t1r is designed for a ctr and leaves room for a cat. I had a carsound with custom extensions put in, but a jdm itr or ctr cat will work.
Old Apr 12, 2004 | 10:05 AM
westcoaststyle
You can't use a B16 (CTR) header on a B18 block. The header isn't tall enough to wrap around the block.
Old Apr 12, 2004 | 10:50 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Actually the header is identical to the 96 spec jdm itr header and does fit b18's. Holla back youngin woo woo!!!
Old Apr 12, 2004 | 01:38 PM
Snoopy's Avatar
Snoopy
been there done that
:werd: the b16b has the same block height as a b18
Prelude girlie
Showroom
32
Aug 22, 2004 08:44 PM
mschmohl
Do It Yourself
4
Feb 11, 2004 03:39 AM
KKTPP
5
May 25, 2003 03:04 AM
TunerTL-S
Dec 18, 2002 08:01 AM
Sushiboy
92+ Civic/EL & Del Sol
4
Aug 20, 2002 06:46 PM
