Sway Bar Install 92 civic
Old Apr 12, 2004 | 01:52 PM
92eg6's Avatar
92eg6
99 CG3 Owner
Originally Posted by RST531
I think so, but im not positive, Im just letting you know what I've read.
https://www.honda-acura.net/forums/s...ighlight=megan
I would suggest getting SRR
where would you get them from and how much?
Old Apr 12, 2004 | 02:17 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
Definitly get some mounts and whatnot so you don't tear out your subframe.
I thought it would never happen to me, and it did. But now I have a frankenstein rear mount - with 3/8" diamondback steel plate welded onto the subframe that my rear-sway is mounted to... that thing will outlast my car.
Old Apr 12, 2004 | 02:30 PM
RST531's Avatar
RST531
http://www.perpetualconcepts.com/
Old Apr 12, 2004 | 04:11 PM
92eg6's Avatar
92eg6
99 CG3 Owner
do you have a pic, i am having trouble picturing it
Old Apr 12, 2004 | 04:15 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
he's getting the 14mm rear bar, not the ITR mang I don't think theres much risk of subframe tear out with that dinky bastid.
Old Apr 12, 2004 | 04:19 PM
white_n_slow
it's my D in a B
Originally Posted by 92eg6
its more like 60 bucks a peice for front LCA's without shipping
Sorry, but if you pay that much for LCAs, you're never gonna get anywhere. Its called looking around you can't just find them over-priced somewhere and resign yourself to it. Did you check the FS forums here? on H-T? Partstrader? Hondaclassifieds? Not to mention local junkyards? You're blowing the LCA problem way out of the water. Getting these things is not the end of the world.
:edit: I would also recommend calling up these Megan racing people and asking them directly if you can replace the bushings in their LCAs w/ ES polyurethane... If so, that would probably make for a pretty decent LCA. ES rear LCA and shock bushing kits will be ~$30 together (you have to get both in order to replace all 3 bushings).
Old Apr 14, 2004 | 09:28 AM
92eg6's Avatar
92eg6
99 CG3 Owner
i talked to megan racing, they said there lca's do not even come with bushings that you are supposed to use the stock ones that come with your car, which explains why some peoples might tear, if there bushings are bad, they use the stock bushings hense poly's that are made for your car will fit. says a tech at Megan Racing. so i think i am gonna buy my poly's from nick at Mako Performance cause he has awsome prices, and get the LCA's.
wich will work good. i talked to a local machine shop about cuttin and welding the brackets i am making and they said they will look at the metal , its zinc plated, they said that would be strong enough and they would guarentee there welds to not break, so i am pretty confident in that.
let me know what you all think
Old Apr 14, 2004 | 11:30 AM
white_n_slow
it's my D in a B
well if you've got decent bushings, those LCAs should be fine. Let us know how the brackets work out... glad you're getting a decent machine shop to do it... Although I'm curious wether the cost of machining will justify the savings.
DC Sports
Dec 29, 2003 10:18 AM
DC Sports
Nov 10, 2003 08:26 PM
in4red6
Jul 6, 2003 04:42 AM
tokyoracer
Mar 15, 2003 01:22 AM
Unjockable
92+ Civic/EL & Del Sol
6
Jan 4, 2003 12:16 AM
