when turning...
Old Apr 5, 2004 | 09:54 AM
mjej's Avatar
mjej
Default when turning...
Hey all well my car is really really slammed or dumped which ever, it's a 98 any how when i turn the steering wheel all the way i here a squeal or some kinda noise, is it the cv boot? or joint? if so do you know how much that ranges to get fixed?
Old Apr 5, 2004 | 10:08 AM
zeroseven's Avatar
zeroseven
CV joints click when they go bad i dont think they squeal but maybe. Look under your car and see if your boot/s are ripped. $60 for a remanufactured cv shaft. Don't know what a reboot kit cost probably 25-30.
Old Apr 5, 2004 | 10:09 AM
flyromeo3's Avatar
flyromeo3
power steering pump about to pump out of your engine.
Old Apr 5, 2004 | 10:11 AM
mjej's Avatar
mjej
what do you mean??
Old Apr 5, 2004 | 10:57 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Means power steering pump is prolly going bad. Go to a shop, get them to look at your power steering pump, cv axles/boots. It's more than likely one of those. Good luck!
Old Apr 5, 2004 | 11:07 AM
G-M-W's Avatar
G-M-W
when i turn i slide outta my seat
i want some real seats
Old Apr 5, 2004 | 11:48 AM
DaUthaWhiteMeat's Avatar
DaUthaWhiteMeat
all show :( 4now!
could be just the power steering belt catching...happened after my swap, and had the same exact problem you describe.
Old Apr 5, 2004 | 11:50 AM
Xplicid01's Avatar
Xplicid01
if ur cars lowered it could be the wheeling biteing the plastic wheel well cover. i had the problem and could figure it out so i took out the cover and no more squeek or bite
Old Apr 5, 2004 | 12:01 PM
monicle's Avatar
monicle
Repo.Jackmoves.Com
check your power steering belt/fluid level
Old Apr 5, 2004 | 02:17 PM
flyromeo3's Avatar
flyromeo3
what do you mean??
MAybe your power steering pump is about to go.
When you turn the wheel its pumping fluid to lubricate the turning parts ( forgot name.....drunk right now ) IF not alot of fluid is being circulated around the joints, hinges etc... it will make a grinding noise.
Similar to two pieces of metal being rubbed against each other without some lubricate in between to limit friction.
or your cv joints could be bad.
