when turning...
Old Apr 5, 2004 | 03:25 PM
bambbrose's Avatar
bambbrose
Originally Posted by flyromeo3
MAybe your power steering pump is about to go.
When you turn the wheel its pumping fluid to lubricate the turning parts ( forgot name.....drunk right now ) IF not alot of fluid is being circulated around the joints, hinges etc... it will make a grinding noise.
Similar to two pieces of metal being rubbed against each other without some lubricate in between to limit friction.
or your cv joints could be bad.
thats partially correct.. it does lubricate moving parts.. but the main purpose of the power steering pump is to push fluid on a piston.. similar to how your brakes' pistons work.. it pushes to help you turn the wheel.... but if you're drunk then I'll give you a break
Old Apr 6, 2004 | 08:57 AM
mjej's Avatar
mjej
awsome i'll check it out thanks guys.... I have one more question though when i take off i here some type of (dun dun dun dun) like goes faster when i excellertate but it eventualy goes away, kidna sounds like what a exahust leak would be, but i don't think it is, i know it's not the belts cuz i got them changed. any suggestions?
Old Apr 6, 2004 | 10:31 AM
Running925's Avatar
Running925
Your Powder Coater
If ( dun dun dun dun ) is actually (click click click click) Then CV's... You might just wanna run that thing to the shop & have them look at it.. there are a lot of noises that sound similar.. & without us being able to hear them for our selves.. it's hard to tell ya.. & as far as your power stearing goes.. check the fluid too!
Old Apr 6, 2004 | 11:35 AM
mjej's Avatar
mjej
nah it's not a clicking noise, sounds exactly like exhasut leak but i dont know.
Old Apr 6, 2004 | 02:09 PM
jon5240's Avatar
jon5240
thats pretty werid...have u used regular power steering fluid? u have to use HONDA power steering fluid
Old Apr 6, 2004 | 06:40 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Originally Posted by mjej
Hey all well my car is really really slammed or dumped which ever, it's a 98 any how when i turn the steering wheel all the way i here a squeal or some kinda noise, is it the cv boot? or joint? if so do you know how much that ranges to get fixed?
Prolly your wheels/tires rubbing your fenderwells because you are
slammed
Autocross Help Page
Old Apr 7, 2004 | 06:05 AM
mjej's Avatar
mjej
the power steering fluid is fine it's totaly full, and it's not my wheels hiting my finders at all that's a totaly diffrent sound.
Old Apr 7, 2004 | 07:30 AM
bambbrose's Avatar
bambbrose
jack up your front end.. put the car in neutral, and spin the tires with your hands.. then turn the wheels all the way to one side and do it again.. let us know what you find.
Old Apr 7, 2004 | 10:22 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
mine makes a squeaky noise too
(I havent found the source either)
Old Apr 7, 2004 | 11:14 AM
Jafro's Avatar
Jafro
I'm made of meat!
If you just got your belts changed, then it probably IS the belts. They may not be tight enough. Either that, or they're too tight and your power steering pumps bearings are begging for relief. The belts should only have about an inch of deflection at their longest point. Any more than that, they will squeal. Less than that can cause excessive wear on your accessories.
