Power Window Help Please
Old Apr 2, 2004 | 05:01 AM
digitaltyrant's Avatar
digitaltyrant
Noob
Default Power Window Help Please
I have a 1999 Civic and twice in the past 2 weeks the window has popped out of the front rail. I put back on and it works fine. It doesn't seem loose. Should I just replace the front rail?
Old Apr 2, 2004 | 06:26 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
Check to make sure that the bolts that hold the rail in place are snug. also check the rubber lining in the rail cause sometimes i will bunch up and bind on the window. If both look good use some silicon spray to lube up the track and it should clear up the issue.
Old Apr 2, 2004 | 07:16 AM
digitaltyrant
Noob
I'll try that. Thanks for your help.
Old Apr 2, 2004 | 12:20 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
There is a service bulletin on this complaint. I can .pdf it to you if you want.
If your car is a 99 si then it probably just needs the rubber run channel replaced to fix it for good. I think the four doors got a new regulator as well. I'd have to look at the .pdf again.
Int3gra'd
4
Feb 17, 2004 08:19 AM
skylane
Do It Yourself
5
Nov 17, 2003 12:14 PM
DMA94ls
5
Sep 6, 2003 10:30 AM
slowcic1
Jul 21, 2003 03:54 PM
