1998 honda please help!!!
Old Mar 31, 2004 | 03:49 PM
honda9882's Avatar
honda9882
Default 1998 honda please help!!!
i have a 98 civic ex with a d16y8 it has intake, 4-1 dc header, exhaust, aem fuel rail, b&m fuel regulator, unorthodox flywheel, act street/strip clutch.
The block has block support, arp bolt-kit for rods, arp head studs, crank grind, decked block, bore and honed block, balaced, floated rods, surfaced head .020" and srp pistons 10.5:1. some other stuff cant remember.
the problem isnt happening constantly but when i hit the gas to accelerate i will rev but suddenly bog and sound like it isnt running on all cylinders. Also getting an eradict fuel pressure on my air/fuel ratio gauge. It is not throwing any codes and has run ok on a hx ecu havent found another p2p ex ecu to try.
ANY THOUGHTS OF WHAT IS HAPPENING ANYONE?
Old Mar 31, 2004 | 04:05 PM
TTT's Avatar
TTT
It seems like a problem with your fuel system- maybe fuel filter is clogged, low fuel pressure, or a leak in your fuel ignition system. Try going through and checking all your components of your fuel system.
Old Mar 31, 2004 | 04:08 PM
Running925's Avatar
Running925
Your Powder Coater
Kinda sounds like u'r starving the engine from fuel. Check pressure..
also check to make sure all u'r plugs are fireing
Old Mar 31, 2004 | 04:19 PM
honda9882's Avatar
honda9882
fuel pressure is fine, plugs are firing i just put some MSD wires on it was doing this before that. could it be the ecu that would throw a code right?
Old Apr 1, 2004 | 08:56 PM
illicon2003's Avatar
illicon2003
you've got 200 horsepower, that's what's wrong. haha
Old Apr 1, 2004 | 09:01 PM
illicon2003
PS check your plugs, wires, dizzy, and ignition stuff. Then start foolin' with the fuel.
Old Apr 1, 2004 | 10:39 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
I would do a compression test if i were you, if it doesn't feel like it's firing on all 4 cylinders it usually isn't. BTW why the hell do you have a dc header instead of a lovefab turbo manifold on that motor if it's already built?
And i better not hear anything about him having 10+ compression so he can't turbo. All the fast turbo honda's (400+whp) all run high compression pistons on purpose (help spool up, increase flow). Besides when you're sleeved, decked with ARP studs you can take it all day long (provided enough fuel and good tuning)
Old Apr 3, 2004 | 08:13 AM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
:yumyum: mmmm.... 400+whp
But yeah, you should check your dizzy and ignitions stuff first, then check fuel
Old Apr 3, 2004 | 03:08 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
A MSD 6A is plenty good for spark, just make sure you have good spark plug wires/plugs and fuel is a whole nother story.
Kev
Accord
Sep 20, 2003 02:41 PM
AcuraFanatic
News & Rumors Archives
Jun 28, 2003 09:53 PM
2001DAEWOOLANOS
92+ Civic/EL & Del Sol
2
Apr 13, 2003 11:01 AM
