Ask simple and basic questions part IV
Old Mar 18, 2004 | 03:55 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
Originally Posted by oc_civic
ok then thats where i got it from....
hell if they were interchangeable then every ricer with an LS motor would snatch up a GSR/SI/ITR valve cover and claim they have vtec
Old Mar 18, 2004 | 03:59 PM
oc_civic's Avatar
oc_civic
mcc racing
lol thats where i got it from.. i vaguely remember some local ricer buying a valve cover on ebay for some strange reason... and he informed me that said valve cover fit all twin cams.. unreliable source.. sure.. but i think thats where i got it from.. i KNOW his physicaly fit.. so i assume it was one of said interchangeable ones..
Old Mar 18, 2004 | 04:02 PM
Wharbone's Avatar
Wharbone
Originally Posted by raiden571
what type of tray fluid should i use on a 95 civic, and is it necessary to change the filter while doing it? difficult?
It will take about 2 quarts of Honda MTF. Filter?
It is not hard to do.
Old Mar 18, 2004 | 04:04 PM
Civic2Scooby's Avatar
Civic2Scooby
there is a filter on Auto trannies
Old Mar 18, 2004 | 09:23 PM
TTT's Avatar
TTT
you can reset it with a key... they normaly reset it when you get an oil change then it will go to yellow and then red... when its time to redo your oil.. i have never checked but i would guess its around 3k miles
I think I remember reading somewhere that red changes at 7,500 miles, I would guess that yellow changes at 3,000 because that seems to be an important mileage... guess I will look around some more.
Old Mar 18, 2004 | 09:30 PM
TTT's Avatar
TTT
Originally Posted by b16aEGcivic
actually you can put b series throttle bodies on D series manis with a lil modification...its a relatively cheap bigger throttle body mod... h:
Yeah, I knew the throttle bodies had a chance of matching up, you have any idea about intake mainfolds? Actually, would there be any improvement even if they did match up?
Old Mar 18, 2004 | 10:35 PM
Civic2Scooby
they dont match up, but if you really wanted to I am sure you could modify one to fit...dunno how much it would do
Old Mar 18, 2004 | 10:45 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
using b series throttle bodies on d series intake manifolds is possible. same pattern is i remember correctly. someone will have to correct me if i'm wrong.
b series vtec and non vtec valve covers are not interchangeable.
non vtec valve covers may be (example b18b1 on b18a1)
dumb yet useful info on valve covers.
in 98 the non vtec valve covers changed in design, prior to 98 they had a similar design to the b18a's.
Project EVA - The Track Package
Project EVA
Old Mar 19, 2004 | 04:39 AM
Wharbone's Avatar
Wharbone
its manual
But he doesn't have an auto. h:
Old Mar 19, 2004 | 05:18 AM
Solracer's Avatar
Solracer
NASA-VA Hyper-Announcer
No need the Y8 Manifolds for the D16 seriers are great manifolds, puy a y8 with a larger throttle bodie and you see and feel a decent gain, when I get some extra chash this is one of the things I am planning on doing.
