could a bad MAP sensor
Old Mar 15, 2004 | 10:35 PM
S2Kev's Avatar
S2Kev
Originally Posted by Bumnah
map sensor is on the throttle body. if you look at the back of the throttle body they have carved out a route for air to go uptowards the map sensor for reading. there are no vacuum lines connected to a map sensor. vacuum lines are all on the intake manifold.
if you unplug your map sensor while the car is running your car should turn off.
Am i even in the ballpark of this thread, I feel as if I'm talking about something completely different.
What's the problem?
You're confusing a tps with a map sensor. Tps is located on the throttle body. It's operated by the throttle plate, the more it opens, the more voltage the tps sends to the ecu to compensate for load.
Map sensor needs a vaccum line to sense manifold pressure and vacuum. More manifold pressure and less vacuum = higher voltage sent to ecu and vice versa.
Old Mar 16, 2004 | 04:41 AM
qtiger's Avatar
qtiger
MAP is mounted on the throttle body on newer B series engines.
Old Mar 16, 2004 | 10:36 AM
Civic2Scooby's Avatar
Civic2Scooby
ok...
gen1 - map sensor is attached via a vaccum hose
gen2 - map sensor is mounted to the throttle body...now that that is cleared up....can anybody help me? h:
Old Mar 18, 2004 | 04:31 PM
Civic2Scooby
boooomp
flamedcivic1998
92+ Civic/EL & Del Sol
4
Nov 3, 2007 03:24 PM
reddemon009
Aug 9, 2003 10:21 AM
AwwsChwA
Engine Swaps, Tech & Tuning
4
Apr 30, 2003 01:43 PM
ZiviCase10287
9
Apr 12, 2003 06:06 PM
ManTiS
2
Mar 11, 2003 03:39 PM
