changing back to honda oil from synthetic?
Originally Posted by vassil3427
Stick with Synthetic, if your motor isnt burning oil now, and doesnt have leaks or anything. Synthetic is MUCH better than normal dino oil. Well worth the extra $$ if you ask me...
It only causes leaks if it has had a bunch of gunk built up inside and the seals are worn out. But if you had synthetic in for awhile...you're fine
I agree with the above. Also you CAN switch back to regular oil with no problem.
Just a stupid thought, but say someone was burning oil. Wouldnt it be better to have synthetic in? because synthetic burns 10 times hotter than normal oil(Or something in that area). Wouldnt you feel less loss of power?
Durign engine break in, you want to use a conventional oil, so that things arent' TOO slippery, and seat properly, as engine mileage increases, it is more acceptable to switch to a synthetic to mitigate frictional wear.
-PHiZ
-PHiZ
During engine break in, you want to use a conventional oil, so that things arent' TOO slippery, and seat properly, as engine mileage increases, it is more acceptable to switch to a synthetic to mitigate frictional wear.
-PHiZ
-PHiZ
Originally Posted by Paul
synthetic doesn't burn unless your motor already burns oil. synthetic doesn't create leaks, it only leaks worse where there were leaks before.
Howitt
Apr 25, 2003 03:16 AM
