Has anyone used an hid shield on their civic?
Old Jan 21, 2004 | 11:55 AM
switzltek's Avatar
switzltek
Default Has anyone used an hid shield on their civic?
I was wondering if anyone has used this type of shield on their civic, and if it worked out?
The link is:
http://www.casperselectronics.com/c...re/commerce.cgi
product # 103016
Old Jan 21, 2004 | 01:20 PM
Nelson's Avatar
Nelson
Administrator
Link isn't valid.. but I know what that is.
I have not tried it, but that is what people would need to use if they want to use a D2S/D2R Xenon bulb in their H4 housing. I strongly believe it's a must, for reducing glare.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jan 21, 2004 | 01:52 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
pomansouth retrofitted some HIDs into his 5th gen. You may ask him. :dunno:
Old Jan 21, 2004 | 02:19 PM
blurr
Guest
Posts: n/a
mine came built on the bulb.. but it's a low and hi beam kit so the shield covers the bottom so all the light reflects off the top of the reflector and down toward the road.. i actually had to remove the stock shield that's inside the housing so that the hid one will fit..
for hi beam the bulb retracts so that the lighting goes through a slit on the bottom allowing for hi beam.
Old Jan 22, 2004 | 06:24 AM
switzltek's Avatar
switzltek
Blurr, Does the Black headlight housing reduce the glare produced by hids? and do you have any pictures of your lights against the wall or on the wall, if so please post them. Thanks
Old Jan 22, 2004 | 09:59 AM
pomansouth's Avatar
pomansouth
for some reason that bulb doesnt look like a hid bulb.:dunno: any how, how does the mechanism work? does the bulb move or the shield move?
Old Jan 23, 2004 | 04:45 PM
pomansouth's Avatar
pomansouth
bump for the unreplied question that i asked.
Old Jan 24, 2004 | 05:55 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
you did a damn clean job removing the housing and factory shield...
Old Jan 25, 2004 | 02:02 PM
blurr
Guest
Posts: n/a
Originally Posted by pomansouth
for some reason that bulb doesnt look like a hid bulb. any how, how does the mechanism work? does the bulb move or the shield move?
the hid bulb is within the shield. the bottom is pretty much completely shielded with the exception of a small slit (approx. 1/8") near the base of the shield. the hid lighting reflects off the top of the housing and shines down on the ground.. the bottom is shielded so it doesn't blind anyone (pretty much like the lexus). if you look at the lexus hid pattern, you'll notice that you only see light reflected off the top half of the reflector, not the bottom.
for high beam, the bulb retracts back so the arc of the bulb will be where the slit is letting the light shine through to reflect off the bottom of the housing and shine up.
i dont' have any lighting pictures yet.. i'll try to take some tonight.
and the black housing doesn't really have much effect on lighting whether positive or negative..
Old Jan 28, 2004 | 04:27 PM
A03's Avatar
A03
I have some of the caspers shields, and they are probably the best ones you can get if you are going to implant HID into a H4 housing. Unfortunatly, even with a good adapter the civic headlights are still pretty badly glaring. The beam pattern is somewhat narrow, but even and well flowing with the caspers shields.. the main problem is just excessive light flying high and annoying other cars (even with the good shield it does this). You will also lose your high beams.
I had my set of shields anodized black, so less yellow reflects upwards and you get a little more of a blue'ish looking light, but it didn't help the glare situation. The end result for me was to retrofit xenon projectors, then build a better set with xenon projectors. Once you go drive in a OEM xenon projector car, it will change your perspective on HID.. The housing and aiming device means the world, the bulb itself means far less then you'd expect.
