engine problem???
Old Jan 11, 2004 | 02:56 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
water pump, or the water pipe that leads to it.
Old Jan 11, 2004 | 03:01 PM
radtw1234's Avatar
radtw1234
internal... damn that sucks, is there a tech writup on how to replace it? or anything i should look out for? do i have to remove the engine mounts?
Old Jan 11, 2004 | 04:23 PM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
No, engine mounts stay right where they are. It's the exact same service as the timing belt - t-belt cover, belt tensioner, crank pulley, etc. Any halfway decent guide can walk you through it. The crank pulley bolt can be a real SOB, though... that's about the only tricky part. I did the entire job on my old 82 Volvo with NO prior mechanical experience of any kind in about 2 weekends... and had virtually no problems.
Old Jan 11, 2004 | 04:39 PM
radtw1234's Avatar
radtw1234
yea.. its an auto what the hell do i do to stop the crank from moving, i bent the shit out of a scewdriver already
Old Jan 11, 2004 | 05:25 PM
gots_a_sol's Avatar
gots_a_sol
there is a special tool that fits inside the crank pulley(if you noticed, it has a hex design) and then a 1/2" breaker bar fit into a tab on that
Old Jan 12, 2004 | 06:17 AM
sxecrow's Avatar
sxecrow
Banned
heh wned:
Old Jan 12, 2004 | 03:42 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
What you do is take off the "flywheel cover" and stick a screw driver in between the teeth on the torque converter (or flywheel if you have a 5spd), and slowly turn the crank until it locks into place, then just go to town on the bolt. The screw driver should hold the crank in place easily. The closer to the front or back of the tranny that you can do it, the better. Less risk of cracking the bell housing.
