D16Z6 Head On A D15B7 Will it work.
Old Jan 2, 2004 | 10:19 AM
94CIVICDX's Avatar
94CIVICDX
Default D16Z6 Head On A D15B7 Will it work.
Good news I think I just went to my uncles junk yard and he has a D16z6 engine in a car that was rear ended. I am taking the head he said I can have it. Can I put that head on this motor? Does anyone know of a write up for that swap and do I have to have the ecu? and do I have to wire anything? and do I have to change the tranny?
Thanks
Old Jan 2, 2004 | 11:45 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
all u really need is the head, ecu and all the vtec wiring and solenoids. u wont need to change the tranny. if i were u id take the whole engine if the rest of it is fine.
Old Jan 2, 2004 | 11:47 AM
supermac88's Avatar
supermac88
not OG but Old School
no he needs an ECU and he needs to run VTEC wiring
Edit: sorry misread above post
Old Jan 2, 2004 | 12:16 PM
94CIVICDX's Avatar
94CIVICDX
Is there any write ups on how to run vtech wiring? And what about the timing. Would that be set normally?
Old Jan 2, 2004 | 12:41 PM
flappy188's Avatar
flappy188
O.G. SON!
take the whole motor, d15's are GARBAGE!!h:
Old Jan 2, 2004 | 12:50 PM
94CIVICDX's Avatar
94CIVICDX
Is there just a motor that I can swap that would just be plug and play. One that doesnt require wire modification? And that I can use my tranny in. I dont care about switching the ecu as long as that is plug and play to. I dont want to have to rewire the whole car.
Old Jan 2, 2004 | 12:52 PM
Kai's Avatar
Kai
Rotorphile.
If you have access to the whole motor, take the whole motor. That will save you the expense of a set of head bolts and head gasket, plus you get a free .1L.
Old Jan 2, 2004 | 07:21 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Dude, I know you're worried about the wiring on a hybrid, but you need to just buckle down and research it. People swap motors every day and they work. Just learn about what harness to use and use the whole motor. It's a WHOLE lot more work to do a head swap and get everything right than it would be for you to just use the whole motor, get the right harness and use the correct ECU.
hih
Old Jan 3, 2004 | 08:22 AM
DeadCivic's Avatar
DeadCivic
If I was you I'll stick to the B7 and swap the head only. I have a hybrid and I didn't regret losing the Z6 block. I'll let you know why:
The B7 with the Z6 head will increase the compression, pistons are high, Z6 pistons are low. Because I'm NA, that gives me more torque on the wheels. I used the P28 ECU and ran only two wires: VTEC solenoid and Oil pressure, don't needed to re-wire the whole car. If you do the swap, the cost of it will be no more than $300 in gaskets, timing belt, sparks, water pump and other stuff you will need.
Also another reason to stay with your block is that you know what you got under the hood. The other engine, is in good shape? If you need more info regarding the swap I'll more than glad to help you...
Old Jan 3, 2004 | 12:16 PM
Spike's Avatar
Spike
JDM whore
Don't bother with a D15. Go ahead and spend the $ to do a swap...it'll be better in the long run. A z6 is a very capapble motor!
I have a nearly complete Z6 swap I could sell you for cheap and you could play around with it.
It needs a rebuild though :/
