Lowering question...who' done this?
Originally Posted by metalman
well, with the adjustable kybs, i could just keep it pretty stiff, and not have problems, right? also, correct me if im wrong, but if i had a larger offset, wouldnt i have more problems since the tire would stick out farther? the offset is measured from the middle of the center of mass of the rim, to the edge, right? if i flare the fenders, a larger offset would screw things up more, wouldn't it? this is my understanding.
You definitely need to do a search on the net. All your simple questions can be answered with Google.
Higher number (ie: 45) is a higher offset than a lower offset (ie: 35). Higher offset will pull the wheels more under the fenders, but lower offset will push the wheels further out from the center of the car (aka low rider look).
Autocross Help Page
Autocross Help Page
Originally Posted by dawrenn
Whats the right offset for a 99 Civic coupe? I have Si wheels.
Autocross Help Page
Autocross Help Page
Originally Posted by CivicSiRacer
Why don't you read the whole thread. I answered your question already.
Then he said this:
2+ inchs will cause havoc on your camber. I know it did on mine with less drop then that. The alignment wont fix your camber. It will fix Caster and Toe but the camber will still be negative and you wheels will be tilted in noticeably proceeding to wear out the insides of the tires prematurely
Am I going to need a camber kit or not?
Si wheels are made for your car :slap: ...you dont need to worry about having the wrong offset on factory wheels :squint:
Honda offsets are usually +40-+42
I thought the offset had to do with the size of the tire?
Autocross Help Page
Autocross Help Page
This is my tire size: P 185/65R15 Is this the wrong size? Will I have rubbing issues? I am going to be lowering my car 2.25 inches. Am I going to need a camber kit? This is what someone said about getting an alignment:If i were you i would definately recommend a camber kit. That is a pretty substantial drop and it will affect your camber. I got a front and rear camber kit for mine and i only dropped it about 1.8 inches or so. You could go without it but it will go thru tires fairly quickly and i think it is better to just get the camber kit and do it right the first time rather then replacing tires often due to bad camber. Then I said this: I heard if I get an alignment I will be fine.
Then he said this:
Then he said this:
Getting an alignment on a Honda Civic you can only adjust toe not caster. With a camber kit you can adjust camber. But with a 2" drop I'd say you'll be fine without a camber kit. Anything more than a 2" drop and it's recommended to get one.
I'm dropped about 2.25" and I dialed in MORE negative camber since I autocross alot, but I also have 0 toe front and rear and my tire wear issues are nonexistent.
Autocross Help Page
Autocross Help Page
First of all yes that is the wrong tire size for your car. Stock is 195/55x15" but you can also use 205/50x15" without any ill effects.
What will the wrong tire size effect? What is caster? I will be dropped 2.25" in the front and 2" in the rear. All I am going to be using the car for is daily driving. How did you get 0 toe in the front and rear?
Originally Posted by alphaxxn
This refers to the angle of the steering axis in relation to an imaginary vertical line through the center of the wheel when viewed from the side
