Lowering question...who' done this?
Old Dec 12, 2003 | 05:01 AM
EddieK's Avatar
EddieK
Originally posted by Grifter
i had neuspeed race (yellows) on tokico blues (later)
the car sit flush with the tires at 195/55/15
is this an si lip or a type r lip... and is it real?
Old Dec 12, 2003 | 07:08 AM
incublinkus's Avatar
incublinkus
JDM Fan Boy
Originally posted by txhatch
This car has the eibach sportlines.
What wheels are on that red civic?
Old Dec 12, 2003 | 08:19 AM
BassmintPimpin's Avatar
BassmintPimpin
EBP'n It!
My Si sits about the same height as his with my Tanabe DF210 springs.
Old Dec 12, 2003 | 08:39 AM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
cut neuspeed race springs. tires were inside the fender. 205/40/16
Old Dec 12, 2003 | 08:53 AM
Grifter's Avatar
Grifter
they are the same thing
yes it was real
Old Dec 12, 2003 | 09:50 AM
metalman's Avatar
metalman
Originally posted by CivicSiRacer
Anything lower than 2" will be about right. But you should get ready for a rough ride. You will also need the correct wheel size, offset and tire size to make it work.
im running 205/55/15s on a 38mm offset and im going to be dropping it 1.4 in the front and 1.2 in the back on the eibach pro-kit, with kyb agx adjustable shocks. will this be ok? i dont envision any problems, but im not an expert like most of you. also, this will be on a 92 civic 4 dr.
Old Dec 12, 2003 | 09:52 AM
randomtask77's Avatar
randomtask77
Wanderer
Getting it flush would depend on your wheel/tire size. Sounds like you want to put some 17's in your car.
Old Dec 12, 2003 | 05:46 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
mine is 1.8 and its perfect.
Old Dec 12, 2003 | 07:41 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
neuspeed race
File Type: jpg
Old Dec 12, 2003 | 07:52 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
If you have a Civic you will. And that tire size is the wrong size for your car your car must feel like a slug.
What size wheel are you running with those? Cause with a 15x7" wheel you need a 42-44mm offset to work.
Autocross Help Page
