How To - Swapping a H22 into a CIVIC
Project Car - H22A Powered Integra
A conversion from B18C1, to H23A1, to JDM H22A VTEC
PARTS REQUIRED
H Series Motor
A Mount kit (www.jdm****.com) (www.hasport.com) (www.placeracing.com)
Custom axles
Custom Radiator
Custom Radiaotr Fan
Custom Welding of Catalyst
90-97 Accord Shift Linkage, all lines running up to cabin
97-00 Prelude Power Steering Line
General Knowledge of Wiring.
A 92-00 Civic, A 90-00 Integra
A VTEC Ecu (P-13) (P-28) .
January 13th, A Wrecked 95 Integra Gsr was purchased, no motor, ecu, and rims.
FIG 1FIG 2FIG 3
I purchased a Fully Built H23A1 Block, It was supposibly 11.5:1 Compression with Arias pistons, it was bought for 1500 Dollars.
FIG 4FIG 5
MOTOR
Since it was only a block, a head and transmission had to be purchased. Since we were starting off from scratch we needed basically everything. So the cheapest route was to purchase a Blown H23 motor. We searched for weeks and we finally got one, a H23a1 with a spun bearing!
It was purchased at a Local Shop "All Motor Works", we got a killer deal for 900, but that price included....A jdm h22a tranny with lsd! This was great because the motor was built for All Motor, so the high revving H22 tranny would be perfect.
So with the motor finally in hand, we started the long process of transplanting the parts off the blown motor onto the "Mint" block. Many misc. parts had to be purchased for the swap. We of course needed custom mounts because the H22/H23 Design wasnt really made to go into smaller cars (integras, civics, hatchbacks)
MOUNTS
I went shopping for numerous brands of mounts, there was HCP, HASPORT, PLACE RACING, and a few others. HCP was 300 Dollars, Hasport was 650, Place Racing was 650 also. HCP mounts are a duplicate of HAsport mounts, so spending 650 on HAsport wasnt a good idea because u can get the generic ones. But with more research and talking to a few people who have done these swaps told me that HAsport mounts mount the motor too close to the driver side. So i wanted to settle for the best, i went with the Place Racing Mounts. FIG 7
GETTING THE MOTOR IN
With the motor assembled and tranny bolted on, it was time to put the motor in the car. With the place racing mounts, the issue of the motor sitting too close to the driver side has been solved by making a mount bolting on to the chassis and not onto the origional mount, so the stock passenger side mount had to be sawed off. FIG 6
RADIATOR
The Stock Radiator was also intruding the engine installation, so it was removed and the motor was dropped in. We later installed the radiator and it did not fit. So we measured it up to specs and got a custom one made. The Stock radiator fan also didnt fit, it hit the header. So we got a Super Slim radiator fan and installed it.(Pics up soon)
AXLES
With the motor in the car, it was time to do the axles. With HCP and HASPORT mounts, u can use a 90-93 Accord Intermediate shaft, with Integra Axles. But A H22 swap like this inside an integra/civic makes the H22 sits 2 inches lower then normal. This improves center of gravity but should require Custom axles because the motor sits low, which in turn makes the inner joint tighter together and making the axleshaft smaller.
With Place Racing Mounts, the motor sits inside the engine bay pretty much in the middle, but completely elimates the possibility to use the Accord Intermediate shaft, Integra Axles Combo.
I had a local shop in fresno Custom make me my axles for only 90 Dollars, I dont know how much they charge normally because i got hooked up. Custom axles should be 15 3/4'th Inches long.
SHIFT LINKAGE
Some people say you can use a 92-96 Prelude Shift linkage, but nope. For some reason it didnt work on my car. The lines are too long, i talked to a few local shops again and they told me to get a 90-97 Accord Shift Linkage. You will need the bracket, all clips and lines that operate the shift linkage system. Due to the fact that The H Series motor use Cable Transmissions rather then Hydralic like the Integras and Civics use. You will need to drill a hole big enough to run the Cable lines from inside the car to the motor. The hold should be about 10 inchs big to be on the safe side. It is HIGHLY recommended to cover the hole because debri, and water can come splashing in. Also inside the car you will need to drill the shifting bracket to the car. This was fairly simple. FIG 17, thanks to JDM****.com
POWER STEERING AND A/C
My car is not currently running PS or A/C. But I have heard, and know for a fact that all you need is a 97-00 Power Steering Line to get it running. The A/C on the other hand needs a custom bracket to fit the A/C pump. FIG 8
ECU'S AND WIRING
My cars stock ECU wiring was cut because of the previous theft it has gone through. Since I was running a H23, It was non VTEC, so i opted for a P75 ECU. It is a Integra LS Ecu. *Note* If you are running a Integra/Civic ECU, it will need to be chipped to employ the needed fuel for a 2.2+ Liter engine. The reason why i recommend using this Ecu for a H23 swap is because it gets rid of the EGR valve, Knock Sensors, and the Butterfly valve mechanism can be removed for a more direct air flow. I am also using a Non Vtec LS wiring harness. (Pics up soon)
CUSTOM CATALYST WELDING
Of course the Integra Catalyst wouldnt work, Mainly because i am trying to keep it smog legal so a Prelude Cat was used. The end which connects to the cat back piping was welding to fit onto a Integra Cat back, This way I can change headers if i like. (Pics up soon)
With everything wired up, it was time to start the car. All Hopes were up high, but disaster struck when the motor Knocked like a *****! It turns out the motor was over raced and there was piston slap going on. Pissed off, I took the motor back to the owner of it. And owner of a Local Shop also. He refused to pay me back my 1500, and he gave me a bunch of BS on how we installed it wrong. Even more pissed off now, I brought my cousin over, which is the owner of Quick Care. We had a long Unfriendly talk and he finally agreed to pay me back 1200 with a brand new Alpine TYPE R Subwoofer. FIG 15FIG 16
With 1200 in hand, I went to All Motor Works again and bought a long block H22A for 700 only. Mainly because im a good customer and he hooked me up, there was no transmission needed because i already had one. (Pics up soon of new motor)
Now the installation of the H22A was fairly simple, same wiring, the LS wiring harness plugged right up. But we had to install 3 wires, they were for the VTEC Activation. There was also two week delay, because the motor came with no downpipe, so a DC Sport Ceramic Header was ordered. I picked up a P13 Ecu (OBD1 H22A VTEC ECU) and plugged it in. We cranked the motor but it didnt start. We checked for spark and Whola. No Spark. It is a common problem because a resister box was required for the Injectors. My cousin suggested to test a Chipped P28 Ecu. Once again, we went to All Motor Works and they supplied us with a GENUINE, JDM Mugen P28! With it plugged in, we cranked it and it started! Success!!!
The car is finally running and should be hitting mid to low 13s. Mainly because i have Quite a few mods.
Intake
DC Sport Header
Custom Exhaust
ACT HDSS Clutch
Lightweight Flywheel
FINAL WORDS
I have no new pictures of it with the H22 In, however I will be sure to get some. If ANY of you guys need pictures of ANYTHING of the swap, dont hesitate to contact me.
The swap i think went pretty well. If we had all the parts in hand, the swap could easily be done in about a day or two. But be sure to have your axles made, and radiator measured because waiting for them is very time consuming.
Email Supraman28@hotmail.com
FIG 1
FIG 2
FIG 3
FIG 4
FIG 5
FIG 6
FIG 7
FIG 8
FIG 9
FIG 10
FIG 11
FIG 12
FIG 13
FIG 14
FIG 15
FIG 16
FIG 17
PARTS REQUIRED
H Series Motor
Custom axles
Custom Radiator
Custom Radiaotr Fan
FIG 1FIG 2FIG 3
FIG 4FIG 5
MOTOR
MOUNTS
RADIATOR
AXLES
SHIFT LINKAGE
ECU'S AND WIRING
Intake
DC Sport Header
Custom Exhaust
ACT HDSS Clutch
FINAL WORDS
FIG 1
FIG 2
FIG 3
FIG 4
FIG 5
FIG 6
FIG 7
FIG 8
FIG 9
FIG 10
FIG 11
FIG 12
FIG 13
FIG 14
FIG 15
FIG 16
FIG 17
bobbybosche
Engine Swaps, Tech & Tuning
4
06-23-2003 05:19 AM
VN-TEC
8
08-29-2002 04:34 PM
