shift linkage question
Old Oct 31, 2003 | 12:19 PM
metalman's Avatar
metalman
Default shift linkage question
yes, i searched first but couldnt find the answer, so im askin the civic gods for help. im puttin a '93 b18a1 block with a '98 b18b1 head into my 92 lx. can i use a 93 teg shift linkage (because i found one for cheap)? also, i know this is more of a teg question than a civic, but are the headers the same for the two models? this is the setup (i think i gotta pretty sweet deal):
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2437851279
thanks for the help!!!!!!!!!!!!!
Old Oct 31, 2003 | 12:22 PM
Civic2Scooby's Avatar
Civic2Scooby
HEADER!!!
Old Oct 31, 2003 | 12:39 PM
dantastic's Avatar
dantastic
cx power!
from what ive heard, you need a linkage out of a 94+ teg or 99-00 si. any other ones wont fit.
Old Oct 31, 2003 | 01:22 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
:werd: 94+ teg or 99-00 Si is the only ones that will fit. The header should be pretty close to the same.
Old Oct 31, 2003 | 02:45 PM
metalman's Avatar
metalman
Originally posted by b16aEGcivic
HEADER!!!
dawg. relax. three deep breaths as well. vtech is a reason to get mad. i say HEADERS cuz im talkin two different models buddy. anyway, i know the 94+ teg and 99-00 si story work, im just wonderin since its a 93 b18a1 block, if i could use its shift linkage as well. ive only heard about the 94+ teg and 99-00 si for b18b, b18c, b16, etc. Anyone know for sure?
Old Oct 31, 2003 | 03:12 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
The linkage needs to come from a 3rd gen teg, 6th gen Si or a del sol vtec because of the length. It reaches the correct distance back to hook up to the shifter. the 2nd gen teg is shorter, if I'm not mistaken, so you would have to reposition the hole in your floor, make a new console, etc. And that would just be retarded... It's that, get the right linkage in the first place, or get the 2nd gen one and cut and weld.
Old Oct 31, 2003 | 03:15 PM
metalman's Avatar
metalman
so basically what youre sayin is i need the 3rd gen teg linkage BECAUSE im puttin it in a 5th gen civic. it makes no difference what the motor is. correct? thanks bud, appreciate the help!
Old Oct 31, 2003 | 06:38 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I'd be going after the del sol vtec linkage. It's the only 5th gen chassis that came with a DOHC engine in the us.
Old Oct 31, 2003 | 06:53 PM
dantastic's Avatar
dantastic
cx power!
the linkage out of a b16 delsol vtec WILL NOT WORK in ANY OTHER CAR besides another delsol. the shifter in the del sol sits in a different place.
Old Oct 31, 2003 | 11:23 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Then how the hell did I get away with using 5th gen linkage on my sol? Answer me that, smarty pants.:fawk:
