shift linkage question
Originally posted by Bakeoff
Then how the hell did I get away with using 5th gen linkage on my sol? Answer me that, smarty pants.:fawk:
h:
cx power!
I used 5th gen D series linkage on a d sereies motor in my sol. So, it obviously is the same length. Then, why would you not be able to use the sol vtec linkage in a 5th gen when it fits a sol?
cx power!
the del sol linkage does not work in the 5th gen's with a b swap. I made the mistake of ordering it with the thought in mind that it had the b series and so did mine now. It ended up being just a little too short.
I know this is just extra information but the 97 Del Sol VTEC B series linkage is about 2 inches longer than the 99-00 Civic Si or 94+ integra B series linkages. When I swapped the B16A2 into my 6th gen civic I had to cut 2 inches out of the Del Sol VTEC linkages in order for them to fit my car.
Conclusion: Del Sol VTEC B series linkages are 2 inches longer than other B series linkages.
