New Dyno numbers at 12.9 psi
Old Oct 31, 2003 | 01:32 PM
Smurf's Avatar
Smurf
Dancing Banana Driver
turbo + high compression = Higher numbers = high risk
turbo + lower compression = lower numbers -> able to boost highe -> higher numbers = lower risk
Old Oct 31, 2003 | 01:36 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
i'm a n00b when it comes to engine tech and stuff....how would you go about lowering or increasing your compression?
Old Oct 31, 2003 | 01:38 PM
Smurf's Avatar
Smurf
head gasket, new pistons.
Old Oct 31, 2003 | 01:42 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
A piston kit h:
Westcoast thats some nice numbers man and thats some of the smoothest curves I've seen on the dyno :thumbup:
Old Oct 31, 2003 | 01:46 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
Originally posted by westcoaststyle
ENGINE
Block
B18C1 Swap
JE/SRP 9.5:1 pistons
Eagle "H" rods
ARP rod bolts
Total Seal rings
Cylinders bored 0.0010 over
Cylinder Compression is 185 lb/psi in all cylinders
Honda green & brown rod bearings
Summit Racing main bearings
Balanced & blueprinted crank, rods, pistons, flywheel, clutch, and crank pulley
Unorthodox racing crank pulley
ACT XT-SS clutch
B&M short shifter w/ Energy Suspension bushings
Clutchmasters 7.5lb flywheel
Acid dipped block
New conversion kit (bottom end gasket set - Summit Racing)
Custom 2.5" piping back to a universal Apexi N1
Venom dipstick (polished)
DC Sports battery tie-down (polished)
Energy Suspension motor mount inserts
Prothane motor mount inserts
Head
Port matched on the intake side
3 angle valve job
Decked
ARP head studs & nuts
Acid dipped & glass bead blasted head
All new head gasket/seal set (OEM Honda)
OEM head gasket
JDM ITR red valve cover
DC Sports wire cover (polished)
Magnacor 10mm plug wires (red)
MSD Blaster external coil w/ distributor cap
Hondata Intake Manifold Gasket
Fuel
AEM fuel rail (red)
AEM high flow fuel filter (silver)
RC 550cc injectors
GSR throttle cable and bracket
B&M adjustable fpr
B&M fuel pressure gauge
Ignition
MSD Blaster External Coil
NGK-R Spark Plugs
Misc
P52 '94+ Del Sol DOHC VTEC AC mount (to keep my AC... until I removed it for the turbo)
All mounts and caps are painted flat black
TURBO
MaxRev stainless steel manifold
MaxRev 2.5" downpipe
Garrett T3/T04E turbo
TiAL 35mm wastegate
Greddy Type 24 FMIC
Blitz Super Sound Dual Chamber BOV
Custom piping
Greddy Profec-B SpecII electronic boost controller
Engine Management
OBD1 P72 ECU
Hondata S200B EMS
GM 3 BAR MAP sensor (Hondata)
and a partridge in a pear treeeeeeee.
:db:
dude if you want higher numbers you need to change your boost fluid at least twice a week. and make sure your V6 doesnt have a hash rotary.
Old Oct 31, 2003 | 01:47 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Nice numbers.
Heh, you lower your c/r to 9.5:1 to run more boost, but that's why my c/r is stock. Damn brittle Chrysler pistons.
Old Oct 31, 2003 | 01:52 PM
NeverBX's Avatar
NeverBX
ya but hondas arent boost dependant.
:db: j/k
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Originally posted by Crash&Burn
He has lower-than-stock compression.
And?????
My friend has a similiar setup with 9.5:1 pistons and a thicker head gasket. He makes close to 400whp at 14psi.
Old Oct 31, 2003 | 01:57 PM
Smurf's Avatar
Smurf
I love how people brag about thier friends.
Old Oct 31, 2003 | 01:59 PM
NeverBX's Avatar
NeverBX
my friend is the governor of california!!!
he can take care of the fires too cause he played a firefighter in collateral damage.
