New Dyno numbers at 12.9 psi
Old Nov 13, 2003 | 12:02 PM
  #41
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Originally posted by NeverBX
ya but hondas arent boost dependant.
:db: j/k
My motor isn't, the turbo eclipses run anywhere from 7.8:1 (1st gens) and 8.5:1 (2nd gens). If I boost mine, it'll be around 8.8:1 compression to leave me some room for tuning.
Old Nov 13, 2003 | 12:11 PM
  #42
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
Not that I know much when it comes to FI and what kind of numbers you're 'supposed' to be running. But I found them to be a bit low too... I would have expected more from a fully built engine on 12 lbs....:dunno:
Old Nov 13, 2003 | 11:31 PM
  #43
Jafro's Avatar
Jafro
I'm made of meat!
Why stop at 8.8:1? Trying to run over 24PSI? Do you have a 1g or a 2g?
Just paid for my JE 9:1 .020's for my GSX. My eagle rods arrived Tuesday. ARP hardware shipped today. I'll be hitting 22 PSI on them, and I bet a 4g63 would hold way more than that with this setup. I stayed with the 2g head and intake manifold to maintain higher-than-1g intake port velocity. That really helps with fuel atomization and it also helps when you're running higher compression. 1g intake manifolds and intake head ports are actualy too big. That's why the 2g 4g63's got bumped to 8.5:1. They "fixed" the intake ports.
Josh... 2" intercooler piping? Are you serious? For cryin' out loud... you've got a turbonetics hybrid. Get some pipes that fit your turbo's flow maps. Go here... http://www.burnsstainless.com You'll have to fab it, but there are mandrel bends, transitions, and straights of all different sizes and materials. But if you end up with Wiggin$ clamp$ on all of your pipe joints, I'm going to drive down there and slap you. Exhaust shops are only good for rolling beads on the ends of the 2.5"-3" pipes you bring them (hint hint...)
I called TRE today and requested that my GSX's tranny receive a Viscous Coupling Eliminator. This allows me to change it from AWD to FWD by locking the output shaft and the transfer case together with a splined shaft. That means I can dyno it locally in FWD mode. Nobody here has an AWD dyno, so tuning has always had to be done at/on the track. :rockon:
Old Nov 13, 2003 | 11:38 PM
  #44
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
so many big words and things i know nothing about but wish i did.....:bowdown:
Old Nov 13, 2003 | 11:49 PM
  #45
Jafro's Avatar
Jafro
I'm made of meat!
It's all about flow and efficiency... Boost doesn't make power. It's how much air you can move. You have to move CFMs, not add PSI. That 2" piping isn't helping. It's almost 1/4" smaller than your throttle body. PLEASE tell me it's not press-bent...?
Old Nov 14, 2003 | 06:42 AM
  #46
Redcivic's Avatar
Redcivic
One of the original OG's
Bastard
Old Nov 14, 2003 | 11:16 AM
  #47
ManInCamo's Avatar
ManInCamo
Old School Crew
Jealous of the curve. numbers are good, but the curve looks great.
Old Nov 14, 2003 | 11:40 AM
  #48
Wharbone's Avatar
Wharbone
when are you going to hit the track and break 12's?
Old Nov 14, 2003 | 02:43 PM
  #49
Smurf's Avatar
Smurf
Dancing Banana Driver
never
Old Nov 14, 2003 | 05:03 PM
  #50
Bumnah's Avatar
Bumnah
So OG it hurts.
running 1 bar to get a 12 = boooo
Project EVA - The Track Package
Project EVA
