New Dyno numbers at 12.9 psi
Old Oct 31, 2003 | 10:29 AM
Civic2Scooby's Avatar
Civic2Scooby
awesome numbers man
Old Oct 31, 2003 | 10:53 AM
EKHatchRacer's Avatar
EKHatchRacer
damn those are some good numbers, whats your engine setup?
Old Oct 31, 2003 | 10:57 AM
RaVen_CiviC's Avatar
RaVen_CiviC
CTR = Fun
i want a turbo!!!
Old Oct 31, 2003 | 11:26 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
Good job, once i get my turbo on, and build my motor we all ( meening the boosted gang) need to have a Dyno shoot out, starting @ like 5psi and going up to max. See who gots the best numbers.
Old Oct 31, 2003 | 11:36 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by str8edgexx
I was being sarcastic.....you might be putting out a little more power than my stock (except for my K&N filter ) Y7....maybe
:chuckles: Might... maybe... :fawk:
ENGINE
Block
B18C1 Swap
JE/SRP 9.5:1 pistons
Eagle "H" rods
ARP rod bolts
Total Seal rings
Cylinders bored 0.0010 over
Cylinder Compression is 185 lb/psi in all cylinders
Honda green & brown rod bearings
Summit Racing main bearings
Balanced & blueprinted crank, rods, pistons, flywheel, clutch, and crank pulley
Unorthodox racing crank pulley
ACT XT-SS clutch
B&M short shifter w/ Energy Suspension bushings
Clutchmasters 7.5lb flywheel
Acid dipped block
New conversion kit (bottom end gasket set - Summit Racing)
Custom 2.5" piping back to a universal Apexi N1
Venom dipstick (polished)
DC Sports battery tie-down (polished)
Energy Suspension motor mount inserts
Prothane motor mount inserts
Head
Port matched on the intake side
3 angle valve job
Decked
ARP head studs & nuts
Acid dipped & glass bead blasted head
All new head gasket/seal set (OEM Honda)
OEM head gasket
JDM ITR red valve cover
DC Sports wire cover (polished)
Magnacor 10mm plug wires (red)
MSD Blaster external coil w/ distributor cap
Hondata Intake Manifold Gasket
Fuel
AEM fuel rail (red)
AEM high flow fuel filter (silver)
RC 550cc injectors
GSR throttle cable and bracket
B&M adjustable fpr
B&M fuel pressure gauge
Ignition
MSD Blaster External Coil
NGK-R Spark Plugs
Misc
P52 '94+ Del Sol DOHC VTEC AC mount (to keep my AC... until I removed it for the turbo)
All mounts and caps are painted flat black
TURBO
MaxRev stainless steel manifold
MaxRev 2.5" downpipe
Garrett T3/T04E turbo
TiAL 35mm wastegate
Greddy Type 24 FMIC
Blitz Super Sound Dual Chamber BOV
Custom piping
Greddy Profec-B SpecII electronic boost controller
Engine Management
OBD1 P72 ECU
Hondata S200B EMS
GM 3 BAR MAP sensor (Hondata)
Old Oct 31, 2003 | 11:40 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
What the hell is wrong with your setup? :thinking: You should really start looking into shit cus that aint right.
Old Oct 31, 2003 | 11:59 AM
westcoaststyle
What do you mean? What do you think I should be running?
Old Oct 31, 2003 | 12:16 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
A hell of a lot more. You setup sounds real fricking nice (except no sleeves :fawk: ) but your numbers are real low. My friend chris used to make 270+whp and 230tq on 12psi and that was on a stock internal b18b.
Something has to be wrong.
Old Oct 31, 2003 | 12:21 PM
Smurf's Avatar
Smurf
8's! haha. noob's
your dyno chart look like a hatch, maybe its telling you to get one
Old Oct 31, 2003 | 01:16 PM
Crash&Burn's Avatar
Crash&Burn
He has lower-than-stock compression.
