Hints for axle install
Old Oct 25, 2003 | 09:11 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default Hints for axle install
Anybody got any hopefully hints on how to get the axle to go in all the way?? On my passenger it out a little bit and my driver side is out alot. I have to pull them to put in new oil seals and i was wondering if anyof u ran into this prob.
Old Oct 25, 2003 | 09:19 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
I know mine is an eclipse but most FWDs are the same. I just took the suspension arm (that bolts up to the a-arm) and beat it against my fender, while having someone hold the axel near the hole. Couple of hits and it popped right in.
Old Oct 25, 2003 | 09:21 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
put the axle in as far as you can with your hands, then take a hammer and whack the end until the rest goes in. :goodjob:
Always works for me. Doing that tomorrow actually.
Old Oct 25, 2003 | 09:23 PM
HatchVX's Avatar
HatchVX
Do u hit the part that goes in to the tranny or the part that goes through the hub??
Old Oct 25, 2003 | 09:24 PM
westcoaststyle
the very end of the axle. the part that goes into the hub. Hit it before you put it into the hub.
Old Oct 25, 2003 | 09:40 PM
HatchVX's Avatar
HatchVX
cool thanks alot
Old Oct 25, 2003 | 10:06 PM
Daniel's Avatar
Daniel
Gahhh, hitting scares me. I simply lined it up, pushed the inboard end in first. It would only go in so far, so my dad got down there and attempted to manually twist it slowly why I applied pressure to the inboard CV joint. Eventually, it reached the sweet spot and just slid right in and clicked. Then I put the outboard end into the hub and was done with it! Reassemble from there!
Old Oct 25, 2003 | 10:46 PM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
I used a rubber mallet:thumbup:
Old Oct 25, 2003 | 11:20 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Get it in as far as you can, then slide it into the knuckle, and swing the knuckle to pop it into the tranny. No damage to the axle, and no damage to the knuckle.
Old Oct 26, 2003 | 12:24 AM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
DING DING DING!!! we have a winner
but usually my boy is in the garage with me so when i do axle replacements on customer cars,..i usually just have him pop the axle into place,..he just shoves that bastard till it clicks,..6'3 pushing 300 pounds,..having friends like that usually has some advantages h:
