Top speed (2000 civic Si)
Originally posted by hondatech
I don't care what motortrend says, I hooked up a honda pgm tester to my civic and my speedo was fast only by 2 mph then actual. So I still don't see how you got 127 at 140.
the margin of error on most if not all speedo goes up as the speed increases.
i know in my car at 60 i'm doing about 59 but around 120 indicated is more like 110-112 ish.
also a cheaper way to find out the speedo accuracy (well cheaper than getting clocked by a police car :exnbp: ) is to borrow a GPS. most decent ones will give you the speed read out and it's 99% accurate.
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
or you could be a hondatech and have a honda pgm scanner, im going to do it today, i'll hit 138 or whatever then look at the datalist for my speed sensor and see what it's actually doing.
okay but don't get killed or busted for speeding
but keep in mind that would be one data point. also do you have the stock tires/wheels? I know my speedo became much more accurate when I changed tires to a slightly larger size
LCD Squad #0001
LCD Squad #0001
