Cam Sensor Melting
Old 02-13-2006, 05:45 PM
ONEIL92LEGEND
ONEIL92LEGEND's Avatar
Default Cam Sensor Melting
I Am Changing 3.2 Engine's In A 92 Legend.when I Took The Timing Cover Off The Used Engine With 68k To Change The Timing Belt And Water Pump The Cam And Crank Sensor Insulation Has Melted Down The Block To The Crank Sprocket.checked The Blown Motor It Was The Same Way.is This Normal And Should I Replace It?
Old 02-13-2006, 06:26 PM
ACURAmechanic
ACURAmechanic's Avatar
I have worked a an ACURA dealership for over 7 years and have NEVER changed a cam sensor on a 2nd gen legend or RL. Our parts department does stock the part and sell quite a few to independant shops, presumably for customers that dont need the part replaced.
I have seen cars with all of the insulation melted out and the sensor functioned fine. It is very common. If you look on most RL/Lenends near the oil filter you will see some of the insulation oozing out from behind the timing belt cover.
Old 02-14-2006, 02:24 AM
ONEIL92LEGEND
Thank You This Is A Great Place To Get Ideas And Answers. My Local Dealership Was Not Any Help.thanks Again!
Old 02-15-2006, 02:47 PM
DrOlds
DrOlds's Avatar
The only problem it caused me when I did my belt was that it glued the timing belt cover to the block! Thought I had missed a bolt.
Old 01-21-2007, 02:15 PM
legend 32
legend 32's Avatar
Default stuff
dont worry...all acura seems to lose the isolation.
they will work forever...with or without that slimy stuff
Old 04-11-2007, 06:50 PM
spotted zebra
spotted zebra's Avatar
Default Melted Sensor
Hello, The sensor is fine. I have seen dozens (probably more) of melted sensors & only replaced one. It had a leaking cam seal & swelled up until the cam gear dug into it. Slap the new belt on & get on with life. Your OK.
